oil preasure
Old Dec 1, 2007 | 06:47 PM
shodan's Avatar
oil preasure
I know its stupid but what is that gage is for?
It stays like 2 bars over half.
My lat car didnt have it
Whats the difference when its on high or low?
Old Dec 1, 2007 | 08:01 PM
Jasonawojo's Avatar
It is essentially the same thing as a dummy light. It either indicates pressure (just past the middle), or no pressure. I don't recall the exact psi that triggers it, but I believe it was down in the 5-7psi range.
Old Dec 1, 2007 | 09:08 PM
Soravia's Avatar
I had it at the middle with 4 quarts of half dirty and half clean oil on a dirty filter.
I drained and put on Purelator PureOne filter and 5 quarts of Castrol GTX 5w30 oil and it shot up to 2 bars over the half.
I suppose two bars over the half is a good place for it to be.
Old Dec 1, 2007 | 09:46 PM
Jasonawojo's Avatar
Thats strange, I didn't think it varied aside from just past the middle or L..
Old Dec 1, 2007 | 11:17 PM
You need a new pair of glasses.
Its a dummy gauge, no matter what you do, it goes a little bit beyond the middle area. I have NO idea what Mazda is thinking, I mean a *functional* oil press sensor dont cost that much ... they stop doing it since I think 03 or 04 on Miata, not 100% sure.
That gauge actually serves 1 purpose, if it stays at L even when your engine is on, that means your Engine is going bye bye. Thats about it I guess.
Old Dec 2, 2007 | 10:40 AM
Soravia's Avatar
Is it possible to put in an aftermarket pressure sensor in place of the stock?
Old Dec 2, 2007 | 11:30 AM
Rx8urZ's Avatar
i think racing beat sells something that will actually make it sense oil pressure . check out tere site
Old Dec 2, 2007 | 11:59 AM
Jasonawojo's Avatar
It doesn't modify the existing dummy pressure gauge though, you install a separate set of gauges to show real oil temp, coolant temp, and oil pressure.
Old Dec 3, 2007 | 10:24 AM
SilverStreak's Avatar
Jason is correct full set separate guages.
As far as modifying the actual Mazda guage to read, it can't be done. The first Miata's had a working gauge that was changed to a "dummy" gauge mid 90's and there was a way to get it working by installing an actual sensor and then "calibrating" the gauge face. But the RX-8 guage doesn't work the same way so a pressure sensor won't work with it.
Old Dec 3, 2007 | 11:23 AM
You guys are correct; the Mazda gauge is in fact a 'dummy' gauge. (very much like the temperature gaguge. )
If you wanted real time oil pressure, I'd go with the racing beat gauge pod.
Old Dec 3, 2007 | 12:22 PM
You're wrong :P
the temperature is in fact a *working* gauge, but the problem is that, by the time it moves beyond the usual *middle spot*, your engine is already on her way to rotary heaven. It moves @ like what? after 220f I think.
Thats why I installed bunch of *real* defi gauges.
Old Dec 3, 2007 | 12:26 PM
hence why I said it was "Much" like the oil pressure. (note: did not say it was exactly like the Oil gauge )
Yup, here's what I did when I got sick of the oem gauges.
Old Dec 3, 2007 | 12:34 PM
Soravia's Avatar
Do you have to drill the pan to install those or do they just fit in to replace the OEM sensor? Won't that throw off the ECU if the OEM sensor doens't send signals to ECU?
Old Dec 3, 2007 | 12:37 PM
you cannot just *replace* what ever Mazda has. Cuz the Mazda *oil pressure* switch is pretty much like an on/off switch. as soon as there is a little pressure it will *move* to the mid point. and its really *deep* inside the engine area you cant really access it easy.
for oil temp and press, all you need is the oil filter adapter. Like RB or Annversity or Greddy. I had Greddy before but for some reason it leaks, I probably used the wrong bolt on it. ahh who cares, I got the Anniversity one and Im happy. no leak whatsoever.
After the adapter you'll need to buy 2 sensor set of course.
For water, same thing , u need a water adapter. I think I post mine up a while ago. you can look at it.
Old Dec 3, 2007 | 12:40 PM
hehehehehe ...
I have something diff ... ahh, same purpose.
Old Dec 3, 2007 | 01:34 PM
Jasonawojo's Avatar
Those are nice, I've always thought red digital ones would go well with the interior.
Old Dec 3, 2007 | 01:41 PM
Yeah, they're almost a pefect match to the oem display. (just slightly brighter, which is good)
I'll most likely be putting up a thread / DIY on those this weekend. (after I take a few more pics)
Old Dec 3, 2007 | 01:47 PM
Nubo's Avatar
Lubricious
It's spelled F...O...R...D
Basically they don't want to have to explain to customers how to understand a real oil pressure gauge.
The real day-to-day value of an oil pressure gauge is that it gives you a good indication of when the engine is fully warmed up. All the more important on a rotary. It's a shame.
Old Dec 3, 2007 | 01:55 PM
Damn, I forgot about Ford.
Sorry to say I will not buy anything thats made by Ford ... when my father was shopping for a new car, I push him to get CX-7, he wants the CX-9. I was like if you want failure, go ahead and get CX-9. Damn ford
Old Dec 3, 2007 | 02:09 PM
Soravia's Avatar
Ford sucks. I've seen their Ford GT. The best damn Ford ever made. Not really that good at all on the finishing touches. Has more issues than RX-8.
Old Dec 3, 2007 | 02:21 PM
U cant compare Rx-8's problems to Ford. They're not even in the same level. in terms of failure.
If Rx-8 has a 5, Ford is like 1000000 times of that.
Old Dec 4, 2007 | 11:40 AM
zoom44's Avatar
You're wrong :P
mine' did that a couple of years ago on the dyno and has yet to even get close to the gates.
Old Dec 4, 2007 | 11:54 AM
zoom44's Avatar
cx-9 is totally mazda. ford makes a version of Mazda's cx-9
Old Dec 4, 2007 | 01:02 PM
Its made in Ford's plant.
so HELL NO
Are you sure ?
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
