Plugs and coils
Old Nov 24, 2007 | 04:11 PM
DarkBrew's Avatar
Extraordinary Engineering
Plugs and coils
Some pictures of my plugs and coils - replaced today - 78k km
P0037 CEL for the rear O2 sensor also replaced today.
Thanks to R.P.M. for making it happen.
Coil replacement
Fluid in the intake
Bad O2 sensor (P0037)
new vs. old leading plug
Leading plugs, front, rear
Old plugs, front, rear
Trailing plugs, front, rear
Two of the old coils.
Old Nov 24, 2007 | 04:34 PM
chetrickerman's Avatar
where did you get them from?
Old Nov 24, 2007 | 04:38 PM
DarkBrew's Avatar
The plugs and coils were from http://www.finishlineperformance.com/ and the rear O2 sensor was from Mazsport on Ebay.
Old Nov 24, 2007 | 04:59 PM
nice, thats the cheapest dealership i have seen
Old Nov 24, 2007 | 05:02 PM
Atilla's Avatar
I am THAT guy
+1 Thanks for the pic's - i was just looking into finding a thread that had pic's of coil replacements -
Old Nov 24, 2007 | 05:03 PM
the problem that i get into when i tried checking my coils, is that large wire that is by or below the nuts that hold on the coils, that and the throttle body
Old Nov 24, 2007 | 05:15 PM
DarkBrew's Avatar
Joe (R.P.M.) used a 1/4" drive set with an extension (4") and pushed the wire just out of the way.
Joe pulled off the intake rubber piece and then we pulled the air box out of the way.
It's a good idea to pull the plug wire before unbolting the coil.
Old Nov 24, 2007 | 05:34 PM
cool, and the nuts are 10 mm right?
Old Nov 24, 2007 | 05:52 PM
Rx8urZ's Avatar
ya they are 10 mm nuts. just use a long extension and kinda push the harness out of the way, its only in the way of the 1 coil the rest are eay. i just checked mine and looks like i will be needing new coils too .
Old Nov 24, 2007 | 05:54 PM
im gonna try checking mine tomorrow
Old Nov 24, 2007 | 09:04 PM
I got 6 OEM plugs from online site for about 10 bux each, Yep OEM, Brand new, with Mazda name on it.
2 Hotter 6 plug, 4 OEM 7 stock range plug
Too bad they dont have trailing plugs for sale
Im gonna replace mine as soon as the weather gets around 60 degrees, for your reference is 28 degrees this morning, and now its 38 @ 10pm
RevMeHarder
Jun 1, 2026 02:30 PM
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
WranglerFan
May 31, 2022 07:51 AM
titaneum_grey
Sep 6, 2015 10:21 PM
