CEL Flashed... Issue?
Old Nov 24, 2007 | 03:07 PM
ModestoRX8's Avatar
I live in cali and normally do not have to let the car warm up for all that long as it is normally hot here.
Well, winter is upon us and I didn;t think about it....
I was driving to work and the engine was still cold, I went to redline the engine (as I normally do on this drive) and from a stop I began accelerating, at about 7K RPM, there was a fairly large hesitation in acceleration, and the check engine light flashed on and off 5 or six times.
I downshifted, and it drove normally the rest of the drive.
After work I let the engine warm up, and repeated this process with no hesitation and no CEL flashing, the car drove like it always does. i have not noticed an issue since.
Was this simply a warm up issue? Or could this be the start of something sinister?
Inquiring minds want to know. I am approaching the end of my warranty so every little thing has me wondering.
I have seen several threads on similiar issues, but nothing exactly like this that I could find.
You guys are always great witht the knowledge, so thank you in advance for any help.
ModestoRX8
Old Nov 24, 2007 | 03:13 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Most likely no real issue but wait for someone with more experience to answer.....but........don't do that again!
You should wait for warm-up and I know you just forgot. Probably a misfire with the way it was flashing.
Old Nov 24, 2007 | 04:44 PM
the answer is in your owners manual.. (read it) the ecu protects the motor till it is warm.. the cel flashing is a missfire. may or may not be related..
Old Nov 24, 2007 | 04:50 PM
Probably a misfire....it will likely have a pending code set.....get it checked to be sure
Old Nov 24, 2007 | 07:39 PM
ModestoRX8's Avatar
All, thanks.
I am definitely going monday to get this checked. I had a repeat of this situation today. The car was warm, but had been shut off for 30 minutes. I started it up, accelerated from 1st from a stop and at 7K rpms, no hesitation, but the CEL flashed at me again. And then it stayed off the rest of the 15 minutes I was driving....
When I go to the dealership, is there anything I should be pushing for them to check?
Plugs? Anything else?
Old Nov 28, 2007 | 05:50 PM
ModestoRX8's Avatar
Issue resolved
Thanks to all that posted, pushed me in the right direction.
The issue was 2 bag spark plugs, they were replaced under warranty, and the car is happy again.
As a side note, I have a K&N air filter ver 2 typhoon, I thought I might get static from them regarding my warranty, but there was no issue with it.
Also, if this helps others... The tech told me (not sure if this is true) that if the CEL stays lit, it is always an emissions / smog related issue, and if it continually flashes, it is an engine malfunction of some sort.
Modestorx8
Old Jan 16, 2023 | 04:19 PM
Alfa30's Avatar
I have the same issue but is blinking just on the time I’m wait for the airbag passenger light shut off but I read here it’s some issues with the maf sensor I buy other one replacement brand and is on but I try to normal driving is rev weird sound like I have bud fuel pump because the sound is normal to cut it to fast. okay now here is my trouble I put back the old one and the car no want to start. I put the maf sensor post to be new and it’s start but with the issue now guys can you help me to figure it what I do or something I do wrong because I try to buy a denso maf brand new and it’s sounds like the old one I have the issue no want to start and now it’s flashing the engine light just open position key. I need help because I doing just for maintenance but now I’m try to keep on it but don’t want to start Mazda 2007 rx8 manual transmission thank for help I’m really appreciate 🤜🏻
Old Jan 17, 2023 | 08:58 AM
BigCajun's Avatar
Originally Posted by Alfa30
I have the same issue but it's blinking while I’m waiting for the airbag passenger light to shut off.
I read here it’s some issue with the maf sensor.
I bought a replacement brand, normal driving it revs weird.
It sound like I have a bad fuel pump because the sound is normal (to cut it to fast) ??
okay now here is my trouble I put the old one back and the car doesn't want to start.
I put the maf sensor (supposed)?? to be new and it starts (but with the issue now)??
^What issue?
guys can you help me to figure it out, did I do something wrong because I try to buy a denso maf brand new and it’s sounds like the old one. (?)
^You put a new Denso MAF on and it does the same thing?
It doesn't want to start and now it’s flashing the (Check Engine Light)??
just open position key. (?)
^The key shaped light is on?
Your post is difficult to understand.
First off, is English your second language?
If it is, I tried to break it down so it's a little easier for others to understand.
Does my version make more sense?
If English is your first language, Holy Wall of Text.
Try thinking about what you're typing and form a coherent sentence.
RevMeHarder
Jun 1, 2026 02:30 PM
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
Randolph Alvarez
May 30, 2016 01:08 AM
DVerdeyen
Sep 13, 2015 11:19 AM
tgaffner
Sep 7, 2015 08:49 PM
