An idea to the fix cel for not having a cat
Old Nov 24, 2007 | 12:29 AM
dmak_el's Avatar
My idea is to have a little pipe maybe 1" in diameter and 3~4" long. Then, stuff some of the cat materials into that pipe. Weld that pipe onto the o2 bung, then weld a nut at the other end to put the o2 sensor in there.
So, i just made a "mini" cat just for the o2 sensor. Would that work?? or am i on crack?
Old Nov 24, 2007 | 01:07 AM
StealthTL's Avatar
Metatron
Would work. Instead of a nut, you would need to get the gas flowing thru it to read the changing gas composition.
I considered it myself, downsides would be - having to cut into the steel of the cat, it's quite thick and isn't ordinary muffler tubing there, and keeping it quiet, it would sound like a good-sized exhaust leak (which it is!).
You're not on crack, it's good thinking.
I just decided to reset the light every couple of days.......
S
Old Nov 24, 2007 | 10:48 AM
Silver_Surfer's Avatar
I4NI
You're both on "Crack"!
Nah, just cant figure out why some people dont get cells without cats.
Old Nov 24, 2007 | 07:11 PM
dmak_el's Avatar
if i have a chance, maybe i will try to see if it works...haha
Old Nov 24, 2007 | 07:52 PM
it has been done. i have seen a photo of it..
Old Nov 25, 2007 | 11:16 AM
dmak_el's Avatar
did it work??
Old Nov 25, 2007 | 01:26 PM
MazdaManiac's Avatar
Part of it may be the '04 PCM, which is different than the '05 and on PCM.
Mine never gets a CEL (unless I do something stupid, like leave the MAF disconnected).
I don't know if a dedicated mini-CAT will work, but a cheaper way to do it would be to build a voltage "follower" for the rear O2 sensor that simply returns a more-lean signal from the sensor that follows the actual voltage swings.
The EMU can do this with the analog voltage map.
Old Nov 25, 2007 | 01:36 PM
quit being an idiot and get a real high-flow cat converter
Old Nov 25, 2007 | 01:46 PM
I'm not sure what this statement means (or accomplishes, other than to indicate that TeamRX8 is incapable of contributing without compensating for his feelings of inadequacy), but a hi-flow CAT may not stop the CEL (none of the hi-flow CAT installations I've seen stopped the CEL at all, though it occasionally allowed for a few more drive cycles), it does NOT offer the same reduction of flow restriction that having no CAT does (especially important on an FI car), it does not significantly reduce emissions on a rotary vehicle and I have yet to see one survive more than a year of severe duty.
Old Nov 25, 2007 | 03:50 PM
Well, there are two methods of posting on this forum as I see it;
Method #1 (The TeamRX8 method):
Q - "I have problem §. Can you help?"
A - "I know how to fix your problem, but I'm not gonna tell you how to do it."
Q - "Why not?"
A - "Because you are an idiot and I'm special."
Method #2 (The MazdaManiac method):
A - "You fix it by using technique XYZ. Here, follow my step by step directions."
Q - "I don't understand."
Old Nov 25, 2007 | 04:13 PM
lone_wolf025's Avatar
Future Rotary User
One of the funniest, most accurate, pieces of humor I have read lately, anywhere!
Gotta agree with that one...
Old Nov 25, 2007 | 04:14 PM
Sad part is, I honestly can't say which is worse.
Old Nov 25, 2007 | 06:41 PM
Well, the end is the same in both examples.
However, neither "means" caused the conclusion - it was a preexisting situation.
Maybe the true ends are not stated in the result?
Old Nov 25, 2007 | 07:32 PM
Easy_E1's Avatar
The bigger questionWHY?
In this case neither end is a means of justification.
Old Nov 25, 2007 | 07:40 PM
Easy_E1's Avatar
Gotta love it. We fix you and your car.
Old Nov 25, 2007 | 07:58 PM
6 syllable words hurt my brain.
Idiot.
Old Nov 25, 2007 | 09:22 PM
chetrickerman's Avatar
ooo, its gettin harsh up in here
Old Nov 25, 2007 | 09:37 PM
Nah. Wait 'till Ray breaks out his thesaurus, then the sesquipedalianism will get really out of control!
Old Nov 25, 2007 | 09:43 PM
haha, i will have to keep an eye on this thread, might learn some new words
Old Nov 25, 2007 | 10:08 PM
Phish806's Avatar
i know this is off topic by gettin back on topic... but the odd thing is is a friend of mine asked me why i did not do this exact thing to fool the cat. he told me that its what people always did on the hondas back in the day .... now i know the 8 is far from an old school civic but kinda odd how i hear his theory and then read it on the boards.
Old Nov 25, 2007 | 10:40 PM
Brettus's Avatar
Boosted Kiwi
Originally Posted by Phish806
i know this is off topic by gettin back on topic....
getting back off topic :
I have a question for Easy E1
How big a "why" does it have to be before it's big enough ?
Old Nov 25, 2007 | 11:18 PM
kennyfrc1's Avatar
If MM were to create an "O2" fooler I would purchase it. I would like to run catless but the only option I can see at this point is using Cobb tuning to remove the post cat O2 code. Thoughts? BTW, my car is an 05
Old Nov 25, 2007 | 11:22 PM
well for the creating part, i think CRH should do it. seeing as he has his own company for making parts for the 8
Old Nov 25, 2007 | 11:35 PM
Indeed. Though, who could design such a thing?
Old Nov 25, 2007 | 11:51 PM
i didnt mean to offend you, i was just saying. if you two worked together, im sure you could come up with something awesome
