Anyone with AEM intake...or not.
Old Nov 21, 2007 | 03:39 PM
bose's Avatar
Reginald P. Billingsly
I just installed an AEM cai, now that wasn't fun in and of itself. but now my car is acting shitty. When I rev it up it goes to 6500 rpm and won't go higher, it's like it's redlining at 6500. Anyone with this intake have this, even if you don't and know what it is/what to do please please help.
After all the labor of doing the intake and this I am simply now. Why do cars have to be so picky?
Old Nov 21, 2007 | 04:08 PM
mikeng714's Avatar
Did you install this by yourself or did you take it to professional shop to install it.
I have my AEM Intake done at the shop. I have more power and loud sound comming out from my muffler. My redline is fine at 9500. NO problem with it.
Old Nov 21, 2007 | 04:33 PM
philsbluerx8's Avatar
the intake shouldnt cause that? did you touch anything else beside the intake?
Old Nov 21, 2007 | 05:32 PM
did you plug the maf back in?
Old Nov 21, 2007 | 05:45 PM
chetrickerman's Avatar
yea, it sounds like its a MAF problem, if its plugged in, make sure its clean
Old Nov 21, 2007 | 07:55 PM
Jon316G's Avatar
Grasshopper
Did you also reset the KAM which contain the sensor profiles?
I had to do this when I installed my AEM CAI.
Old Nov 22, 2007 | 11:41 AM
lepichichi's Avatar
I LuV mY Rotary....
just curious Jon316G, how do you reset the KAM????
Old Nov 22, 2007 | 01:22 PM
Jon316G's Avatar
Grasshopper
Turn the key to the 'ON' position (but do not start the car)
Rapidly press the brake pedal 20x until you see the oil pressure gauge sweep back and forth.
And thats all. You'll find that this is something you need to do as you modify your car.
Old Nov 22, 2007 | 01:51 PM
hmm, wonder if i should do that when i install my midpipe and RB duct
Old Nov 22, 2007 | 01:58 PM
WHEN i stalled my exhaust and intake, Jon taught me that too.....its not gonna cause anything if you do, just about 2 minutes work. so better do it than not.
Old Nov 22, 2007 | 02:14 PM
yea, i might as well
Old Nov 23, 2007 | 10:59 AM
bose's Avatar
I did it myself, and it's really odd, my car did that I made the thread. Then I left work a couple hours later, no one had replied yet so I was worried. Got into my car and she started, revved it up and it went to redline no problem at all, so I don't know WTF but it's working.
Old Nov 23, 2007 | 11:03 AM
we sent an email to your engine and told it to start working again. your welcome
Old Nov 26, 2007 | 12:08 PM
bose's Avatar
obviously it did the trick.
Old Nov 26, 2007 | 01:43 PM
tajabaho1's Avatar
Destroying Threads
reset ur ecu, ur MAF was like WTF when u installed it and didn't disconnect the battery
how did I know? haha, did that too........on the s2k though
Old Nov 26, 2007 | 04:13 PM
Jon316G's Avatar
Grasshopper
From what I understand (and feel free to correct me if I'm wrong) is that the PCM has a battery that holds some data and simply disconnecting the main battery will not clear your KAM (unless you keep the battery disconnected for a few days). That is why you must perform the 20x brake deal after installing "performance" mods to clear the sensor profiles and allow them to "relearn" themselves (plus you won't lose your radio presets).
cliffkemp
Dec 24, 2024 10:48 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
Sato Tatsuya
Oct 5, 2015 03:09 PM
Zube6115
Sep 30, 2015 12:57 PM
