20b
Old Nov 17, 2007 | 11:51 AM
hartge's Avatar
20b
He guys,
I am from Austria and now i wanted to modify an rx8.
I´ve found one with an broken engine.
Now i want to install an 20b engine.
My questions are:
Are there different 20b engines?
Does the 20b engine fits on the original engine retainers?
Fits the 20b engine on the rx8 gearbox?
ok we should make it easy >)
What do I have to change everything?
best regards
tom
Old Nov 17, 2007 | 11:57 AM
Easy_E1's Avatar
Everything. It's not a plug and play conversion. It costs on the average of $10,000 - $15,000. Most that have done it have spent more.
Try the "SEARCH" button.
Old Nov 17, 2007 | 12:36 PM
staticlag's Avatar
The Professor
Theres a direct swap from the cosmo, which is the cheapest route. Then you can also buy a race 20B which is considerably more expensive option but it has strengthened seals and the like.
My understanding is that you need custom engine mounts and a new transmission.
Old Nov 17, 2007 | 12:55 PM
Macius8's Avatar
It'll bolt up to our tranny, but it probably wont last long. rx7club.com has a ton of info on 20b's check it out. And it wont be anywhere near easy
Old Nov 17, 2007 | 03:59 PM
hartge's Avatar
so and what´s about an 3rotor?
would this be an cheaper solution?
greetz
tom
Old Nov 17, 2007 | 05:09 PM
Macius8's Avatar
umm maybe you shouldnt be doing a swap
Old Nov 17, 2007 | 05:13 PM
snipaz2420's Avatar
the bukkake master!
20b = 3 rotor
Old Nov 17, 2007 | 05:39 PM
shaunv74's Avatar
Power!!
greetz
tom
Um yeah...You should do some reading up before posting again. My personal opinion is I would rebuild the renesis with Hymee's Supercharger or Mazsport Turbo.
Old Nov 17, 2007 | 05:44 PM
california style's Avatar
Londons Yellow Peril
Originally Posted by shaunv74
Um yeah...You should do some reading up before posting again.PM Hymee. He's from your half of the planet and has some good insight for you.
Maybe you should read up on some geography! Austria and Australia are in fact a world apart....
Old Nov 17, 2007 | 06:14 PM
Macius8's Avatar
LOL i love this thread
Old Nov 17, 2007 | 06:19 PM
eviltwinkie's Avatar
Old Nov 17, 2007 | 06:24 PM
shaunv74's Avatar
Power!!
More like reading comprehension. I mis-read.
Editing post...
Old Nov 17, 2007 | 07:37 PM
Turblown's Avatar
Boostin'
You'll want a C or D code block, appears most of the A, and B code remans are usually updated with the thicker irons however(C/D). You'll need custom mounts,
different ecu, exhaust, etc. Expect a lot of custom work..
Too bad you're so far away, we have a 20B in stock and we'd love to stuff it in an 8....
OneEvilRx8
17
May 7, 2006 12:25 AM
Greddyturbo1
26
Apr 25, 2006 10:59 PM
yellowRX
Feb 17, 2006 12:40 PM
ASH8
Jan 3, 2006 02:02 PM
Gord96BRG
General Automotive
40
Mar 22, 2005 08:53 AM
