cold engine squealing
Old Nov 14, 2007 | 01:35 AM
Boost it's Avatar
I have a 04 RX8 with 23,000 miles on it, in the last few days I noticed a squealing or high pitched noise when started first thing in the morning. After my 8 warms up it goes away, I talked to the dealership and they say this is normal, which I find interesting sinse it just started. Any imput from my fellow RX8 ers?
Old Nov 14, 2007 | 05:52 AM
Go48's Avatar
Definitely sounds like a failing water pump. Look for a small leak at the bottom of the water pump (front of the engine). Have the service people keep the car overnight so that they can start the car cold in the morning to hear the sound. They can't tell squat without hearing the sound.
Crazy that they would tell you that without listening to the noise. Seems to be the common response when they don't want to deal with a problem, "oh yeah, that's normal".
Old Nov 14, 2007 | 11:42 AM
squeaky belt?
Old Nov 15, 2007 | 03:03 AM
Boost it's Avatar
I had not thought about a water pump with only 23,000 miles, but the noise it is making sounds like that might be my issue. Thanks for the help.
Old Nov 15, 2007 | 06:04 AM
Go48's Avatar
Sure, let us know what you find out.
Old Nov 15, 2007 | 12:45 PM
2k4_8's Avatar
And your positive it's not the air injection? My car does something like that, it's easily heard even while in the car and only while warming up while it's very cold. I thought it was the air injection though.
Old Nov 15, 2007 | 07:21 PM
Probably the air pump......give it a listen when you first start up your car...should stop after a few minutes regardless.
Old Nov 20, 2007 | 12:59 PM
babohan's Avatar
Wht's up 2 U
any update??
Old Nov 20, 2007 | 09:37 PM
lilring's Avatar
Finally a MT
i have that same problem. im taking mine in to the dealership tomarrow. and i have a 2004 with 37000 miles on it, its not a lot so i dont understand why stuff is going out on it
Old Nov 21, 2007 | 09:16 PM
lilring's Avatar
Finally a MT
i just had my 8 worked on today at the dealership and they said all it was, was the alternator belt was lose. but whos knows, it the same dealership that messed my car up before. lol
Old Nov 22, 2007 | 04:09 PM
babohan's Avatar
Wht's up 2 U
errrrr. i have the same problem. hm..
Old Nov 22, 2007 | 04:10 PM
Spinning Sushi's Avatar
I <3 Sushi
It's strange, I get that but only randomly. It would happen like every other morning or two...
Old Nov 23, 2007 | 01:31 AM
slavearm's Avatar
Boost Junkie
Unplug the smog pump and see if the squeel goes away one morning. Pretty easy to tell then. You will throw a code, but it will go away after a few drives and having it plugged back in again.
Old Nov 24, 2007 | 11:08 AM
babohan's Avatar
Wht's up 2 U
wht you find out boss?
Old Nov 29, 2007 | 01:57 AM
Need2Speed's Avatar
i get the same high pitch sound when starting. not every time but every 2nd or 3rd time. it's only while cranking that this happens and goes away the instant the engine is running. could it be the starter?
Old Nov 29, 2007 | 02:26 AM
Kane's Avatar
Senior Member
Typically - I would go with the serpentine belt as the first culprit.
Old Nov 29, 2007 | 02:31 AM
_Logan_'s Avatar
When my coils were going and my car was cranking quite a bit I got a squeeky sound, only squeeked just as the engine first fired
After I replaced my coils and my car stopped cranking the squeeking sound went away
Old Nov 29, 2007 | 04:00 AM
TrochoidMagic's Avatar
is adjusting valve lash
sure way to find out if it is a belt squeak is to have some belt lube ready when its dead cold. WD40 will work too.
start up the car and wait for the squeak, hit-up the belts, and if the noise goes away then its that particular belt. tighten and check slack with motor off.
done!
and if its not the belts making the high pitched noise, then it may be the air injectors making those noise and its normal.
Old Nov 29, 2007 | 08:37 PM
Boost it's Avatar
I am scheduled at the dealership next Tuesday I will keep you informed of the out come. The squealing sound I am having problems with happens after the motor has fired and is running.
Old Nov 30, 2007 | 09:20 AM
lilring's Avatar
Finally a MT
that is what i had, mine was the alternator belt was lose so that might be what it is. keep us updated please
Old Dec 9, 2007 | 06:31 PM
valpac's Avatar
Ahead of its time
I have the same noise when starting cold and goes away after warmup. The sound is a high pitched whine that I have isolated the air pump. May be a bearing noise. Does anyone know the RPM's of the pump? Sounds like this thing is moving.
Old Dec 9, 2007 | 07:08 PM
dmak_el's Avatar
i have squealing belts after i installed my ap pulley. adjusted the belts many times, still doing it. it only squeal for like 30sec to 1 min at cold start, then it will go away.
Old Jan 4, 2008 | 05:30 PM
Boost it's Avatar
Sorry it has taken so long to get back to you folks. The dealership isolated it to the air pump, they have one on order so it is not installed yet but as soon as it is I will let you know if the issue has been erectified.
Old Jan 4, 2008 | 11:03 PM
mazdatech177's Avatar
is "erectified" the same as getting the issue "straightened out" ?
hehehe.. sorry i couldnt resist
Old Jan 4, 2008 | 11:17 PM
chancejat's Avatar
Drive it like u stole it!
mine does the same thing..........after a min or two it just stops........it doesnt fade it just stops i like it just clicks off.....i assumed it might be the ac belt loose and when the ac clutch engages it squeeks ....??????
