Stock Speaker Wires
Old Oct 31, 2007 | 09:21 AM
CostasX8's Avatar
2003 Titanium Grey JDM 6M
Stock Speaker Wires
I was wondering if the stock wires can handle 300Watt RMS speakers or should i change them?(I found it a bit difficult to change them)
Cheers
Old Oct 31, 2007 | 01:53 PM
WikkedOne's Avatar
Deals on wheels
OK first off do you have the bose?
are you adding your own amp?
i seriously doubt your ever going to push 300 watts rms to any interior speaker -
if you only changing the speakers (not amp) and don't have the bose the wires will be fine for now.. -
but if you doing that and want an actual upgrade you should add an amp.. and if you add an amp you will probably have to add new wires anyways. - save yourself some trouble down the road and just do it all at once
there is a "molex" sticky on this forum that helps.
if you do everything you can all at once you save yourself alot of regret and more work later down the line.. trust me.
Old Oct 31, 2007 | 02:17 PM
CostasX8's Avatar
I will be installing the Audiobahn ABC6003V 6.5"& 4" 320W 3-Way Components and of-course i will add amps...I have check the molex thread and looks a bit difficult but if its necessary to change the wires i will.Is it?
Yes, i have the bose system
Old Oct 31, 2007 | 03:16 PM
WikkedOne's Avatar
Deals on wheels
in that case you HAVE to change the wires-
where you would you put the amp where you could use the stock wires?
and the bose has the amp for the rear deck speakers in the trunk and each of the door speakers have their own amp in the door - so you have to run new wires to bypass those amps.
yeah it's a bit tricky but it can be done - WD40 is your friend too..
I had help and found it was easier to remove the doors to get really good leverage but you don't need to- (its only 4 bolts)
Old Oct 31, 2007 | 03:23 PM
CostasX8's Avatar
I bought the LC6i .To connect it, its better to remove the three bose amps, then to connect the wires that are inputs to the bose amps and redirect them to the LC6i or to connect all the wires to the LC6i from the outputs of the three bose amps without removing them?
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
DVerdeyen
Sep 13, 2015 11:19 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
mattymack
Sep 6, 2015 10:33 PM
