inside the air box
Old Oct 27, 2007 | 11:19 AM
chetrickerman's Avatar
inside the air box
yesterday i bought a k&n drop-in airfilter and i installed it, and when i took it apart i noticed something wierd. Inside there, there are two walls on each side of the horn, and i was wondering what they are there for and if it would make a difference on air flow if i took them out? Btw, i give the k&n air filter a 5 out of 5. It did pretty good. I like the sound it gives the engine, and the powerband seems smoothened out while kicking in around 2k rpm. If you need pics i will post them.
Old Oct 27, 2007 | 11:26 AM
expo1's Avatar
He's as bad as Can
The OEM airbox is a well designed unit, I wouldn't expermeint with it unless you have an extra one lying around. Best case scenario 1-2 HP above 7,000 RPM with a poorer idle and more noise.
Old Oct 27, 2007 | 01:55 PM
ok, i will try it and let you guys know
Old Oct 27, 2007 | 03:24 PM
i will let you know how it turns out, but i dont think it will make much of a difference
Old Oct 27, 2007 | 03:39 PM
yea, good thing i didnt
Old Oct 27, 2007 | 10:06 PM
eddiec727's Avatar
so takin out both of those meshes wont harm idle?
Old Oct 28, 2007 | 02:28 AM
screens are there to straighten the airflow.
Old Oct 28, 2007 | 02:48 AM
Brettus's Avatar
Boosted Kiwi
yeah - very important to have straight air .
Seriously - I took my screens out and it has run sweet as a nut ever since .
Old Oct 28, 2007 | 03:41 AM
Spinning Sushi's Avatar
I <3 Sushi
I've removed the two walls inside my intake box a long time ago. The screen is still there though... BTW, look at the design of Racing Beat's REVi Intake Box, it's strikingly similar to the stock air intake box without the flaps...
Old Oct 28, 2007 | 03:49 AM
FIRST TIME ROTA OWNA's Avatar
Hi chetrickerman have you removed the screens yet? is there any noticable difference? can you post pics cheers
Old Oct 28, 2007 | 03:51 AM
I <3 Sushi
i can post pictures mine in a couple of hours since it's dark right now...
Old Oct 28, 2007 | 04:00 AM
I <3 Sushi
By the way, your intake sound will sound a lot louder with the walls are gone. I don't think they're there not for airflow but for sound deadening. For example, look at racing beat's design... it basically is the same airbox with a filter relocated onto the intake pipe and the walls are gone. The box itself is the same size as the OEM one. You can take out the OEM filter and use a dome filter and just clamp it on. I'm pretty sure you'll get the exact same gains as the Racing Beat intake.
Old Oct 29, 2007 | 05:04 PM
I <3 Sushi
Sorry about not having the pics up yet, I'm having some problems with my camera.
Old Oct 29, 2007 | 05:13 PM
tajabaho1's Avatar
Destroying Threads
wont harm jack ****, hell, me and almost all of my rx8 friends here in Socal got it removed (well before, I have aftermarket now)
Old Oct 29, 2007 | 05:57 PM
i only took out one screen and so far so good, the powerband is smoother and it adds a really nice sound, almost fomula 1 car sounding. i will post pics if it the forum takes camera phone pics
Old Oct 29, 2007 | 06:29 PM
ok, the pics dont work, not right format, but i did take out the little walls, and it is a little louder intake sound, especally with the windows closed. Since you were wondering about the screens, i took out the one right behind the horn, leaving the screen farther up the tube which is right ahead of the MAF. For all of you that want a little increase in power, and an increase in the intake sound, and only costing 50 bucks, its worth it. btw, i also changed my oil and used Royal Purple synthetic 5w30, and my engine loves it. It revs a little easier. oh and, when i took out my old filter, it was bad. The filter is supposed to be white or pink, and in the center of mine it was black, so it REALLY needed to be changed. I did also notice and increase in gas mileage. peace.
Old Oct 29, 2007 | 08:45 PM
I <3 Sushi
The panels ARE in the box for resonance/noise-cancellation purposes.
Yeah, that's what I concluded too a while back ago.
Old Oct 29, 2007 | 09:52 PM
I <3 Sushi
For a moment a couple years ago I contemplated drilling "swiss-cheese" holes in the panels as a sort-of stepping stone between leaving them in and totally removing them. Then I decided that I was being a bit too scientific about it all and just removed them.
LOL! Yeah, if you're going to drill into those panels, might as well just remove them
Old Oct 30, 2007 | 07:03 AM
we should just cut off the front part of the air box so the whole filter is out, and then it is exposed to more air! jk
Old Nov 4, 2007 | 07:48 PM
TrochoidMagic's Avatar
is adjusting valve lash
And to think you would have spent hundreds to learn the same thing about aftermarket intakes.
+1.
i have only gotten RB's air ram as seeing the revi display in person at SSX past month was essentially a nicer done version with the inner "ridges" in the box absent and no plates. i already removed the plates as i rechecked the the k&n filter and noticed the dirty areas are concentrated. like CRH said, running without would spead more surface area. and i just don't want the filter to always get dirty/clogged flow in the same concentrated area.
if i would even waste my time modding the stock intake further... i would prolly only cut the air flow ridges thats running horizontally on the top side of the box to match the straighter flowing ones on the sides if you know what i'm sayin'.
Old Nov 4, 2007 | 08:25 PM
well i took out my second screen and the acceleration is smoother, along with a more consistent/smooth idle.
Old Nov 4, 2007 | 09:27 PM
Jasonawojo's Avatar
Thats awkward, I would have expected the opposite. Maybe its the difference between a Mazda and K&N air filter.
Old Nov 4, 2007 | 10:05 PM
Ultralisk's Avatar
11 Bang Bang
But the RB CA Ram intake does help i suppose.... not that im buying that either, im just saving up for FI.
Old Nov 4, 2007 | 10:39 PM
Brettus's Avatar
Boosted Kiwi
Each RX-8 responds differently.
exactly why these things are worth trying .
Old Nov 4, 2007 | 11:23 PM
I <3 Sushi
Maybe I should do a DIY on how to make an imitation RB Intake box... I'll do that now.
