Adding Sub to Bose System
Old Oct 25, 2007 | 11:24 AM
Vader76's Avatar
Hi,
I needed some opinions or suggestions on what sub and amp to add to the system to get some additional bass. I don't want to wake the neighbors or it to be boomy. Nice and clean thumps to accompany the music. I mainly listen to trance/dance. The wife listens to hip hop/r &b.
I already have purchased a 4080 box.
For the amp I was looking at (probably cause its on sale ):
http://www.futureshop.ca/catalog/pro...gon=&langid=EN
And the sub I was looking at:
http://www.futureshop.ca/catalog/pro...0085244&catid=
Thanks in advance...
Old Oct 25, 2007 | 11:45 AM
nate340's Avatar
bad combo the amp is only putting a 116watts out at 4 ohms. if you plan on using that sub you need an amp thats putting out around 300 watts at 4 ohm
Old Oct 25, 2007 | 12:14 PM
heyarnold69's Avatar
Rotary wanabee
a little hint. get an amp that is litterally 2x than what your subs can handle for one basic reason. speakers come and go .. but amps are warenteed for years. plus new tech in speakers .. .ie 4 voice coils .. materials...you may want to upgrade the speakers later. just turn the gain down. by turning down the gain you also ensure that the amp will never ever overheat.
while we are on the subject ... the pioneer shallow mount subs ... dam! my current fav! i have a hifonix zeus amp pushing them ...
Old Oct 26, 2007 | 03:27 PM
Vader76's Avatar
Ok, after a bit more research..
For amp either:
Alpine M450 or Alpine M650 each outputting at 2 ohms..
Sub:
Pioneer ts-w257d4 (dual v coil, each coil at 4ohms)
If I understand correctly, I wire the coils in parallel so the 2ohms from amp will work?
So overall:
Tap into the wires before the Bose Amp. Run those to the speaker level input of the Alpine (or get LOC to run to RCA inputs). Tap in remote on wire to center console power. Power from battery, ground to somewhere in trunk.
Any glaring mistakes?
Thanks....
Old Oct 26, 2007 | 09:48 PM
1stgen8's Avatar
Invest in a good LOC...much better than speaker level inputs.
Old Oct 26, 2007 | 10:00 PM
paulmasoner's Avatar
Asshole for hire
a good LOC can make or break the quality of your sound.
check out Audiocontrol or David Navone's NE-7V
Old Oct 28, 2007 | 01:56 AM
DOMINION's Avatar
I don't buy Kool-Aid
Whats a LOC?
Old Oct 29, 2007 | 01:35 PM
white311's Avatar
9K Smokin!
A LOC keep burglars out of your car right???
Old Oct 29, 2007 | 03:58 PM
white311's Avatar
9K Smokin!
Here is a link to one:
http://www.sonicelectronix.com/item_...TRUNK-LOC.html
Product Description:
Adjustable Line Output Converter (LOC) with Remote Trigger Output
Used when adding an amplifier to a factory radio
Converts the radios speaker level outputs to the lower amplifier RCA level input
Uses audio transformers for noise isolation, is phase adjusted, has 0.5 dB liearity from 20 Hz - 20 kHz
Rolloff at 20 Hz for subsonic reduction
Independantly adjustable channels
2 - 80 Watt Power Handling
+12V DC Trigger Output
0.8V Trigger Threshold
2 Amp Max
Connects to Rear Speakers
Dimensions: 3-3/4" L x 1-1/2" W x 1" H
1-year Sonic Electronix warranty
Old Oct 30, 2007 | 12:03 PM
forbidden's Avatar
If you are in Canada, drop me a e-mail to forbidden@telus.net and I will be glad to present you with some options. I am well versed in car audio and have done work on your car numerous times now. A good LOC is 100% necessary in your 8, after that a correct match of amp to sub to box. Lots of options to choose from, the trick is to do it right.
Old Oct 31, 2007 | 08:43 AM
ZUMZUM_RX8's Avatar
Speeder
are there any pictures or directions on where to hook up the LOC.... I have one already and I am having trouble finding the right place to hook it up, I have the Bose stock system and I don't know if I should tap in behind the radio or if I can pull a signal from the trunk, I just want it to sound the best it can......
Old Oct 31, 2007 | 08:49 AM
white311's Avatar
9K Smokin!
Check the DIY section for wire taps..... you hook it to the speaker wires in your trunk before the bose system amp.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Jst4fun
Mar 5, 2021 07:16 PM
crimson809
Aug 14, 2016 10:03 PM
Learners_Permit
Sep 27, 2015 07:38 PM
