Snapping Noise
Old Oct 19, 2007 | 11:09 PM
Adamrotor's Avatar
Sonic the Hedghog
Snapping Noise
Hi, I've been trying to track a snapping noise. It occurs when car stands after like an 1 hour or overnight during first time reversing only, when turning to the right. As I'm turning and reversing at the same time there is a snap, it occurs once, then I would have to wait about an hour or so to duplicate it again or even a day. Im started to search the forums, but if anyone knows or heard of the problem please let me know.
Thanks, Adam
Old Oct 20, 2007 | 12:14 AM
brake pads locked to calipers.. i get that after a wash often.. but if you are moving and it happens abs test.
Old Oct 20, 2007 | 06:38 AM
Go48's Avatar
Try this:
http://www.finishlineperformance.com...2-04-1301b.pdf
Old Oct 20, 2007 | 07:58 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Both of those above posts are really good Adam. I was going to ask if you parked your car outside at night because I'm with Swoope on the car wash or moisture thing. Mine will snap once occassionally after a rain or wash, and not even when I'm turning or anything, but upon the veery first move after. You can almost tell what it is in this case. The second post is really interesting as well and could very well be the source as it kinda looks like it more closely depicts what you have mentioned.
Old Oct 20, 2007 | 01:44 PM
Adamrotor's Avatar
Sonic the Hedghog
Thanks guys. Yes, the car is outside. I'll look into it and see what I get. I also forgot to mention it comes from the driver front side(wheel area I guess), atleast thats how it sounds. I'll do some tests and keep an update.
Also, GO48 thanks for that post I did clean those earlier this year, maybe it is now just one wheel I'll give it another clean. =)
Old Oct 21, 2007 | 11:42 AM
Go48's Avatar
Notice the lug nut torque spec of 108 ft lbs. for the snapping fix in that bulletin. Seems a bit extreme to me, but you might try going a bit higher than what you now have.
Old Oct 21, 2007 | 05:27 PM
Adamrotor's Avatar
Sonic the Hedghog
Well after some research I discovered not alot, but it seems to do it when it is chilly out. Also while washing my car followed by drying it I kicked the driver front wheel and it snapped it sounds like the caliper just unsticking? Could it be? I'll wait till its cold out. Thanks guys.
Old Oct 21, 2007 | 05:50 PM
Mazurfer's Avatar
Yes, that's very likely as it happens to me after a wash. Especially if you are in there cleaning the calipers thru the rims like I do.
Old Oct 24, 2008 | 02:43 AM
volcomx31's Avatar
Silver Power
i have the same problem and i have an AT..
Old Oct 24, 2008 | 07:57 AM
alnielsen's Avatar
Check for cracks in the lower control arm where it pivots at the chassis.
Old Oct 24, 2008 | 08:00 AM
ZumnRx8's Avatar
RX8 & RX7 owner
never had this problem
Old Oct 24, 2008 | 11:59 AM
EDZRIDE's Avatar
2005 White GT
I had a similar "snapping" sound (in the front end), after backing out of a parking spot, then moving forward; this TSB fixed it.
http://www.finishlineperformance.com...05-08-1948.pdf
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
chadsta
Sep 20, 2015 11:00 PM
