Special Mazda tool to replace oil filter?
Old Oct 16, 2007 | 03:35 PM
xenon's Avatar
I am ready to perform and oil change for the 1st time. I have never done it before and while reading thru the manual it says I need a special tool to replace the oil filter.
Any idea what this is all about?
Old Oct 16, 2007 | 04:20 PM
ZoomZoomH's Avatar
Mulligan User
any of those 'filter wrenches' at the local auto parts store should be able to take the filter out for you... no special tool required.
Old Oct 16, 2007 | 04:25 PM
w0rm's Avatar
PUSHER ROBOT
The factory seal on the original filter can be rather tight. Some people have needed to get the aforementioned filter wrenches.
The only really special tool you need is a hand with an opposable thumb.
Old Oct 16, 2007 | 04:47 PM
Socket7's Avatar
ಠ_ಠ
Some people like to poke a hole in the top of the filter with a screwdriver to let the oil drain better.
Mazda specific oil filter wrenches can be found at your local auto parts store next to the blinker fluid and muffler bearings.
Old Oct 16, 2007 | 04:49 PM
Revvittupp's Avatar
That screwdriver hole can be used to turn the filter too.
Old Oct 16, 2007 | 07:20 PM
gnj152's Avatar
The best is a #5 filter socket!!!
Attached Thumbnails Special Mazda tool to replace oil filter?-dsc_0001.jpg   Special Mazda tool to replace oil filter?-dsc_0002.jpg   Special Mazda tool to replace oil filter?-dsc_0003.jpg
Old Oct 16, 2007 | 07:38 PM
dillsrotary's Avatar
jersey fresh
grip it by hand and wrap it in sand paper, it'll come off.
Old Oct 16, 2007 | 07:44 PM
Special technique. Look forward from drivers side. rech right arm in. Grab it take it off.
Old Oct 16, 2007 | 08:13 PM
WoodsOfGreenRx8's Avatar
can see that going bad....
Old Oct 16, 2007 | 08:18 PM
Ericok's Avatar
Rotary Wanker
Once you punch the hole in the filter, there's no turning back. You're committed to getting if off.
Old Oct 16, 2007 | 08:26 PM
Revvittupp's Avatar
Normally, an oil filter should be hand tight. If it is not, a hole in the side, can be used with the screwdriver to "torque" the first quarter turn, as you now have a lever arm with which you can exert more rotational force. It's not the best way, but it is a way, that requires no additional tools. Usually, I reach in and turn it by hand.
Old Oct 17, 2007 | 12:28 AM
and you are going to get a hole in the side, and get a screwdriver down there how???
i really need to know.. i have read about it for while..
Old Oct 17, 2007 | 06:40 AM
RX8Maine's Avatar
The only reason I put a hole in the top is to let more of the oil drain out. I still get about a teaspoon worth of drippage, though. I hate that g#$&@mn inverted filter!!
Old Oct 17, 2007 | 07:37 AM
Socr8tes's Avatar
I tried this method once on a stubborn filter (on another car) and succeeding only in twisting the hell out of the filter and sheering the top off. If you thought it was hard to remove before...
Old Oct 17, 2007 | 08:50 AM
Just go to your local auto parts store.
find the right size of oil filter, then try each of the oil filter wrench on it until it fits.
buy the wrench, put the oil filter back (or buy it if you dont have 1)
Go home, do the oil change.
Feel good about yourself.
Old Oct 17, 2007 | 09:29 AM
w0rm's Avatar
PUSHER ROBOT
The trick I've found is to poke a hole when I start the drain, when it's all done stick an oil rag down around the bottom of the filter and as I twist it off take the rag with it. I've gotten oil leakage down to a minimum/non-existent.
Old Oct 17, 2007 | 09:32 AM
Wurmfist's Avatar
FEAST!
Once you get the old one off with whatever method mentioned above, buy a K&N Oil filter. The K&N filter has a normal hex bolt head on the end of the filter and if you couldn't get it off with your hand you can just use a socket set. Plus a K&N filter is a really great filter.
Old Oct 17, 2007 | 09:59 AM
Revvittupp's Avatar
I don't know of their filetering abilities, per se, but the frams with the sticky black handguard are easy to use by hand as well. I know my father's construction company ran Fram everything for years, but I haven't checked on them for my 8.
Old Oct 17, 2007 | 10:16 AM
xenon's Avatar
I got a filter wrench and was able to remove the Mazda filter no problem.
I decided to go with the Fram filter PH6607 and Castrol GTX 10w-30. It needed EXACTLY 5qt's of oil because I have the Greddy oil pan.
Old Oct 17, 2007 | 05:17 PM
NoRotorNoMotor's Avatar
Mazda Only. 10+yrs
10w- 30 ??? why that thick???
I'd use 5w 30 or 20
Old Oct 17, 2007 | 08:19 PM
yamajj's Avatar
if you go buy yourself some "hp-1008" oil filters. made by k&n engineering. they have a nut at the top of the filter that you can easily fit a metric socket on.(as said above...except i gave you the k&n part number)
yamajj
Old Oct 18, 2007 | 12:11 AM
xenon's Avatar
I'd use 5w 30 or 20
Do some reading. 10W-30 is what I need since I have a greddy turbo kit.
Some even say 10W-40
Old Oct 18, 2007 | 03:22 PM
Mazda Only. 10+yrs
Ahhh interesting.
I did not know that.
Very interesting.
Old Oct 19, 2007 | 10:25 AM
Ben98gs's Avatar
The "other RX8" owner
If you had that happen then you were not going to get that filter off in the first place. If it was torqued tight enought that you ripped through the filter with the screwdriver then someone overtorqued it to begin with.
I have used the screwdriver method probably about 10+ times. Usually the first oil change after a rebuild (when the motor is out of the car you tend to over torque it because it is SOO much easier to put on because you do not have to twist your arm through everything else when it is installed). I seem to do this on 1/2 of the rebuilds that I do and that first oil change can be a bitch
mr. GrandGame
Sep 9, 2025 10:41 PM
eazzyg
Oct 28, 2022 10:33 PM
Junirol
Sep 22, 2015 06:02 AM
ne0tas
Jul 26, 2015 04:27 PM
