knock sensor problem.
Old Oct 13, 2007 | 08:59 PM
bmxer's Avatar
I am throwing a code p0328 which is the knock sensor. any suggestions on how to fix it? where is it located at?
Old Oct 14, 2007 | 04:00 AM
Jon316G's Avatar
Grasshopper
The attached pic shows you the location of the KS. The spark plugs give you a good idea where you are looking at.
I would fist try to disconnect and reconnect the hire harness. Then reset the KAM (turn the key to 'on' (but don't start the car) and press the brake pedal ~20x until you see the oil pressure gauge sweeps back and forth).
File Type: jpg
Old Jul 10, 2012 | 06:56 PM
Twisties's Avatar
sorry to revive an old thread but were you able to figure out the problem. I have just replaced my engine, and I am getting the same code. Replaced the sensor with the one from my old motor, same thing. Also it wont go over 5k rpm. Could a clogged cat be the issue. The plugs and wires are good. I used the old coils I had which were working fine before i replaced the engine. I am just stumped as to where to start to fix these problems
Old Jul 11, 2012 | 08:45 AM
It's called a service manual. If you open one up it will indicate that if it's not the sensor then it's either a wiring or PCM issue
Old Jul 11, 2012 | 09:23 AM
HiFlite999's Avatar
Replaced the engine without looking at the cat?? Very unwise since a clogged cat could have killed the original engine.
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
tjohnmeyer
Sep 28, 2017 05:03 PM
Evan Gray
Nov 24, 2015 01:00 AM
tommy26Germany
Sep 29, 2015 10:33 AM
