ClutCh
Old Oct 11, 2007 | 01:12 AM
B0wD0wN's Avatar
ClutCh
I got a annoying chirping sound coming from clutch ,anyone had this problem before ?
i just got a new clutch too and same sound again .
when i engaged clutch even a little bit the sounds goes away , then release clutch and it comes back..
could it be release baring?
Old Oct 11, 2007 | 08:37 AM
chetrickerman's Avatar
i dont know if this is the same thing, but when i go out and start my car in the morning and let out the clutch, it sounds like another thing starts spinning. is that normal?
Old Oct 11, 2007 | 12:47 PM
w0rm's Avatar
PUSHER ROBOT
Search throwout bearing.
Also, in your sig you might consider 'learning' the difference between "you're" and "your".
Old Oct 11, 2007 | 03:24 PM
Did you get new throwout bearings (and maybe pliot bearing) for your new clutch install ?
If not then .... that might be the problem.
Old Oct 11, 2007 | 05:00 PM
cjwaggs's Avatar
^" that's" the funniest **** " I've" seen in a minute...
Old Oct 11, 2007 | 05:12 PM
why?
Old Oct 11, 2007 | 07:17 PM
oh, ok, i was hoping it wasnt the throwout bearing, cause i wasnt planning on changing that til the spring when i get my flywheel/clutch
Old Oct 13, 2007 | 03:24 PM
Adamrotor's Avatar
Sonic the Hedghog
It's for sure the release bearing, it lost tention thats why you hear that chirping noise. To make sure it is the release bearing you can do a few things. First, disengaging and engaging the clucth pedal you will hear the noise come on and off. When the clutch is disengaged your putting pressure on the bearing and the diaphragm spring, causing the noise to go away. When engaged the release bearing is barely touching the diaprhagm spring allowing it to free spin a little bit, thus it being without tention it spins easier and chirps. Second, also one way to check it is disengaing the clutch pedal like 1 inch. from fulling engaged position, where you can feel a small pulsation in the pedal and the noise will speed up and get louder, your gently allowing the release bearing to touching the diaphragm spring.
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
