Ask: How to replace HID bulbs?
Old Oct 7, 2007 | 09:24 PM
dEEpsEa's Avatar
MaZdAEr
I have a little bit experience with installation of HID kit when I owned my Mazda6.
But it seems to me that on RX8 it's harder to reach the headlight assembly due to the compact design.
I searched the forum and haven't found a write-up of how to replace the HID bulbs. Does anyone know if there is one 'how-to' thread here, or somewhere else? A link will be appreciated.
I assume the front bumper and assembly need to removed to replace the bulbs, is that true?
Old Oct 7, 2007 | 09:59 PM
G3tR3DDY2GR3DDY's Avatar
yup there are like three or so bolts behind the bumper cover underneath the headlight to take it out... other than that its one bolt on top and a push clip and your done. Not sure about the DIY thread for them, but good luck!
Old Oct 17, 2007 | 09:30 PM
solesko7's Avatar
i want to change the bulbs on my RX-8, how can you tell if your ride is already (hid)? Also how do you get to the fog light assembly to change those bulbs as well?
Old Oct 17, 2007 | 10:48 PM
dEEpsEa's Avatar
MaZdAEr
Thanks, I just read a DIY thread about replacing stock HIDs somewhere (maybe DIY section) yesterday. It turns out a pretty simple to do. But I think removing the two front wheels could make things much easier. (But not really necessary though). I will post the link here if I can find it again.
To tell if you already have HID installed? Stand in front of the car, let a friend turn on the low-beam headlights. If they are HIDs, you will see the bulbs take about .5-1 second to get lights out but it's kind of dim at the first beginning. Right after that, it will take about another 2-3 seconds to reach it's max light output. All of these are because HIDs bulbs are totally different to traditional halogen bulbs --- there are no filament inside. If you don't see that kind of lighting change, you don't have HIDs.
HIDs have much more lighting output and if I 'm right, the stock HIDs are 3800k or 4000k, which give you a nearly 'pure white' color if you look at them from a certain distance (like 20 feet or more).
Banshee8
Sep 2, 2015 03:03 PM
beastman_5
Aug 30, 2015 10:22 AM
CARBONRX-8
Aug 23, 2015 09:52 PM
dylan424
Aug 21, 2015 06:10 PM
Stubbs
Jul 28, 2015 09:23 PM
