04 rx-8 going into limp mode off and on
Old Sep 18, 2007 | 09:58 PM
crucesrx8's Avatar
My 04 rx-8 will drive fine and then out of no where it loses all power. Will not go past 3500 rpm. Can anyone help me....
Old Sep 18, 2007 | 10:34 PM
Jon316G's Avatar
Grasshopper
Does this still occur after you turn the engine off and back on?
If not, then you probably just needed to let it warm up.
If it still occurs, might be a clogged cat or the oil metering pump.
If your car is under warranty take it to the dealer.
More useful information to include:
Have you had all your recalls performed?
Have you had your spark plugs replaced?
How many miles are on the car?
Does your CEL illuminate? If so, what is the code?
Old Sep 19, 2007 | 02:39 PM
crucesrx8's Avatar
I have gone to the mazda dealer in town. They did a recall on the powertain control module. They said they reprogrammed it. I also got all my spark plugs replaced. My car has 93000 miles. The person that had it before me hollowed out the cat, so my car reads emissions. Could that be part of the problem?
Old Sep 19, 2007 | 02:46 PM
Your CAT.
Old Sep 19, 2007 | 02:49 PM
StealthTL's Avatar
Metatron
Could be the water temp sensor - that would put a 3500 rev limit on......
S
Old Sep 19, 2007 | 02:53 PM
Any CELs btw ?
Old Sep 19, 2007 | 03:29 PM
crucesrx8's Avatar
so do you think I need a new a cat? Why would the car be able to run right sometimes?
Old Sep 19, 2007 | 06:29 PM
Jon316G's Avatar
Grasshopper
Still waiting to hear if you got a CEL or not when this happened. If so, what is the code it generates? This will help us to narrow down the possibilities.
Old Sep 19, 2007 | 09:15 PM
crucesrx8's Avatar
Today I went to a couple shops in town and all that came up was o2 sensors needing to be replaced.
Old Sep 20, 2007 | 01:00 PM
crucesrx8's Avatar
now my car is not coming out of limp mode.
Old Sep 20, 2007 | 07:10 PM
Jon316G's Avatar
Grasshopper
Have you tried to reset the KAM?
Old Sep 21, 2007 | 05:30 PM
crucesrx8's Avatar
yes. That is how I would get it out of "limp mode" but it goes right back in after a few minutes.
Old Sep 21, 2007 | 08:05 PM
Jon316G's Avatar
Grasshopper
If you had a bad O2 sensor a CEL should have came on.
I still have yet to hear an answer on if you receive a CEL when it goes into limp-mode and if so, what code does it generate. If you feel that its a bad O2 sensor, replace it. If it doesn't work, then come back and we'll go from there.
Old Sep 22, 2007 | 04:04 PM
crucesrx8's Avatar
ok i will, thanks...
gwailo
May 14, 2024 06:57 AM
9krpmrx8
Oct 13, 2015 01:36 PM
TJSiegrist
Sep 10, 2015 09:29 AM
Tsurugi
Sep 7, 2015 08:27 PM
