Strange idle after disconnecting battery
Old Sep 15, 2007 | 12:16 PM
Fab 8's Avatar
I have been running the REVi without a screen for a few months without any idling issues.
This afternoon, I disconnected the battery to clean the terminals, and after reconnection, I suddenly have uneven idle, including the car stalling a couple of times. Decided to pull the REVi and put in the stock air box (with one screen left inside) and idle was back to normal. Only thing was that the idling speed dropped to 750rpm from the usual 850-950 rpm.
Anyone encountered this strange problem before? Seems kinda strange that a battery disconnection can cause idling issues. I'm gonna reinstall the REVi tomorrow with the screen and see if the idling returns to normal. IN the meantime, if anyone has any other cures or answers, that wld be much appreciated.
Old Sep 15, 2007 | 12:38 PM
kersh4w's Avatar
Hit & Run Magnet
uh, im talking out of my *** here. but possibly resetting the ecu might help.
Old Sep 15, 2007 | 12:40 PM
Silver_Surfer's Avatar
I4NI
Never heard this before. Could your revi airfilter be clogged? Dirty?
Old Sep 15, 2007 | 01:20 PM
SportCoupe2's Avatar
The computer has to re-learn the idle, especially with the aftermarket air intake. Let it idle for about 10 minutes with a/c off and then another 5 minutes with the a/c on. That should take care of everything.
Old Sep 16, 2007 | 02:02 AM
that is kinda correct..
first put one screen in.. it helps a lot.. and it takes about 9 drive cycles for everything to settle down after a ecu reset..
Old Sep 16, 2007 | 10:36 AM
Fab 8's Avatar
Thanks for your help, guys. I disconnected the battery again, then reinstalled the REVi without the screen, and let the car idle for abt 10 mins after that. Seems to have cured the problem, and she's running smooth as ever again.
Old Sep 17, 2007 | 05:48 PM
Thats why it's good to drive it a few miles. Then shut it off then re-drive again.
Like they said it takes a few drive cycles.
This is normal.
Taking off the battery cables will reset the ECU if they are off long enough.
OnebaddRx8
Aug 25, 2019 11:34 PM
Danield97
Sep 30, 2015 05:59 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Evan Gray
Sep 26, 2015 12:30 PM
