Hymee Enhanced Sports Exhaust - My Thoughts
Old Sep 9, 2007 | 09:38 PM
Rimmsy's Avatar
Thumbs up Hymee Enhanced Sports Exhaust - My Thoughts
A couple of weeks ago I ordered a Hymee Enhanced Sports Exhaust for my 8 from Mark, got it shipped and had it fitted here in Adelaide. I thought I might give you guys my impressions of the exhaust after 2 weeks of use.
I have no pictures but I am sure you have all seen Mark's website. The new exhaust has Hymee Enhanced with the logo etched on each muffler. There is a also a plate where the pipe divides to the two mufflers that contains the number of the exhaust and other info. It's 2.5" all through and finished off with 4" tips which fill the exhaust outlets nicely. From the outside the only indication that something is different is the larger tips that stick out a little more than the stock.
I have read a few threads looking at reviews of different exhausts and one of the biggest "problem" with them is that they drone during cruising or are excessively loud. Well I can say that the Hymee does not drone! On idle it is till quite quiet, but the tone of the exhaust has dropped. It doesn't really come alive until above 4000RPM and then you know there is something at the back there. Where before the RX8 sounded like an F1 car, now I reckon it's an F1 car with *****!! During acceleration it burbles and pops and sounds great...a real head turner, especially under hard acceleration.
According to the butt dyno I haven't noticed any real performance gains, but it is definitely stronger down low. I have a rather steep drive way, at low revs the 8 would tend to jerk a little going up the driveway...but no more.
There are a few issues I have found so far. It did smoke and there was a bit of a smell a few days after installation as the packing oil was burnt off, but now all good. I reckon it has caused the 8 to burn a bit rich, but a tune should fix that. Associated with that, it the fuel consumption has gone up but it isn't too bad (nothing rotary owners aren't familiar with anyway!).
In summary, the RX8 now sounds better (who would have thought), better performance down low, much reduced boot heat soak. However, it drinks more petrol and there was initial smoking.
Highly recommended (and Mark's service was good too!)
Thanks for reading!
Cheers
Rimmsy
Old Sep 9, 2007 | 10:02 PM
alnielsen's Avatar
I'm surprised you found an increase in the consumption of fuel. Are you sure that you aren't just accelerating harder to hear the new sound of the car.
Old Sep 9, 2007 | 10:08 PM
Gomez's Avatar
Shifty Bastard.
Glad you're happy with it!
I'm looking forward to seeing the new Hymee exhaust. Having owned an original system of his for three years, I was pretty pleased with the look/sound.
Hymee's website still has pics of the older system on it. Whilst happy with my old Hymee exhaust, there are a few improvements I'd like to see in any future system of his.
I'd like to get rid of the 18" joiner to the midpipe. A whole new midpipe would be much neater and eliminate any chance of gas leakage. I'd like the hangars turned down at the ends to help eliminate side-to-side movement (a-la the factory muffler hangars). I'd also like to see some bracing/strengthening of the Y junction into the mufflers. My system suffered cracking at the point where the pipes entered the mufflers. I had cracks around 50% of the pipes circumference on both mufflers after two years.
I had to get the cracks welded prior to having a roadworthy issued when I sold the car.
Post up some pics when you can, Rimmsy!!
Old Sep 9, 2007 | 10:15 PM
Cromax's Avatar
Buzz Buzz Buzz
You're not using your car enough honey ... it's probably just a lot of carbon deposits that have built up. We'll give her a good run this weekend though yes?
Old Sep 9, 2007 | 10:31 PM
Brettus's Avatar
Boosted Kiwi
Originally Posted by MissyK
I guess that would be my next question - does it really matter how often you drive the car as to the result of how rich it burns etc?
cleaned your MAF lately kal ?
Old Sep 9, 2007 | 10:50 PM
Brettus's Avatar
Boosted Kiwi
Originally Posted by Gomez
Let's keep it on topic, eh?
OK - does anyone know what the differences/improvements are with the new type 2 exhaust . Hymee does not say much on his blog .....
Old Sep 9, 2007 | 11:16 PM
http://hymee.wordpress.com/
a little help.
i am disappointed if the exhaust does not come with a back pipe.. the use the old one from the stock exhaust is not good. although it is 3" .
i would love to know the dia of the inlet to the Y.
Old Sep 10, 2007 | 12:14 AM
Brettus's Avatar
Boosted Kiwi
was 2 1/2" on the mk1 version
Old Sep 10, 2007 | 12:22 AM
Gomez's Avatar
Shifty Bastard.
Thanks for the link, swoopster.
Here's a pic that details what I'm on about:
Old Sep 10, 2007 | 12:23 AM
Rimmsy's Avatar
I reckon the fuel consumption is up a bit due to it running a bit rich, Mark emailed me this as a possible reason:-
"The RX-8’s engine management system, like other modern EFI systems, uses “closed loop” to continually adjust the fuelling to maintain the correct AFR at the ideal level. This is only done at “light cruise” and very mild acceleration. You can check how yours is performing if you plug in a scan tool such as the sCANalyser I developed, as shown at www.performancedesign.com.au. But yes, I have found RX-8’s, like most cars, run rich when in “open loop” when the feedback adjustments are not being made. There are various reasons for this, to detailed to get into here."
But I also agree I am revving it harder just to hear it!
I believe the differences between the Mark 1 and 2 are that the mufflers are embossed with the Hymee Enhanced logo, and a laser etched ID tag. I think the system is still 2 1/2" all the way through.
I will post pics when I can, I am at work at the moment and don't get home until it gets dark. But I will see what I can do!!
Cheers
Rimmsy
Old Sep 10, 2007 | 12:32 AM
Gomez's Avatar
Shifty Bastard.
Search....this is a Hymee exhaust thread.
Old Sep 10, 2007 | 12:37 AM
this is where it might get a bit odd, the back pipe used on the type one. is the stock exhaust pipe.. close to 3"...
and to missy, whats a maf with you? sorry had to do it..
mass air flow sensor..
to op..
please reset your ecu.. it will make things happen faster.. as to the mpg decrease... likely you playing with a new toy...
btw,
brett sorry about scott dixion. it was an exciting race..
to all sorry about wankering up you aus thread!!!!
Old Sep 10, 2007 | 02:05 AM
Brettus's Avatar
Boosted Kiwi
For you kal
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-how-clean-maf-94872/
Old Sep 10, 2007 | 07:14 AM
mirx*8's Avatar
Well, I like my Hymee exhaust as well... back on topic!!
Old Sep 10, 2007 | 07:46 AM
Black-8's Avatar
Rotary noob
From the pic there doesn't seem to be an "end" on the hanger. By an "end" I mean is like a cap that's slightly larger than the diameter of the hanger at the end of the hanger? It's probably easier to have that instead of a bend?
Old Sep 10, 2007 | 08:13 AM
Gomez's Avatar
Shifty Bastard.
Yeah, that'd work.
With four inch tips it's quite noticeable when the exhaust is off-centre in the exhaust shrouds. You just need something to keep the assembly centered.
Old Sep 10, 2007 | 04:20 PM
Brettus's Avatar
Boosted Kiwi
Yeah, that'd work.
yes - burning plastic is not a nice smell - I know from 1st hand experience
Old Sep 11, 2007 | 12:37 AM
Cromax's Avatar
Buzz Buzz Buzz
Yeah, that is a mean feat ... I think I know how to though
Old Sep 11, 2007 | 02:01 AM
Rimmsy's Avatar
As promised, here is a pic of the info plate where the pipes split. The Hymee Enhanced logo on the mufflers is the same as the picture Gomez posted.
Cheers
Rimmsy
Attached Thumbnails Hymee Enhanced Sports Exhaust - My Thoughts-exhaust-002-small.jpg
Old Sep 11, 2007 | 06:34 AM
madkeen73's Avatar
Could the author kindly share what the Hymee exhaust cost to supply, and to fit.
Ta
Old Sep 11, 2007 | 08:47 PM
Andy8's Avatar
This is not an ad!
Madkeen, http://www.performancedesign.com.au/ is the website to purchase the exhaust, can be done by email or call Mark on the number listed on the websites contact page. Also for fitting, give Les at Fat Pipes a call on (32857417), they are situated in the Kallangur/Petrie area on the north side of Brisbane.
Andy
