lagy at low rev help need help
Old Sep 9, 2007 | 02:41 AM
yushinrt's Avatar
hi how are you every one i need help today i was driving back from my mate house normaly and i stoped at the lights and i was trying to take off normaly but my car wasn't moveing and so pushed the gas pedal harder then nothing the few sec later the car starts moving then another stop same thing at got home and just idling my car and it really unstable at the low rev like 750-900 and it moves up and down up and down so i opened my bonnet and asked my mate to just rev the car then i can hear something in the engine(from that area) but at idle makes no noise and my mate that was there said it sounds like it exhaust i don;t know i feel like crying now don't know what to do my car is a 4speed jdm AT that done 56800km and i did change my coil like 9000km ago i have no idea what the problem is need help
i just went for another drive and just notice it ok to drive until i hit 90℃ then the car goes ruff and and does that laggy response no power thing do you guys think it the apex seal ??
Old Sep 9, 2007 | 03:51 AM
Brettus's Avatar
Boosted Kiwi
can you be more specific - is it just lacking power - is the motor reving up and you go nowhere ?
Old Sep 9, 2007 | 05:23 AM
yushinrt's Avatar
when you push the accarater nothing happens at all then few sec later it goes like normal na the motor don't rev up
Old Sep 9, 2007 | 05:46 AM
Hymee's Avatar
Race Steward
Do you have any engine lights? Could you have gotten bad fuel? Have you been playing around under the bonnet, and left a MAF sensor or other connector disconnected? A scan tool such as the one Brettus has in his sig can help diagnose the problem.
Are you running FI or anything non-stock in the engine department? Hard to say from your post.
Cheers,
Hymee.
Old Sep 9, 2007 | 05:51 AM
yushinrt's Avatar
i am running stand with hks airfilter ap pully greddy pully and ti exahust system and a oil catch can and latest stuff i did was ap pully installed 1week ago and today i just cleaned the airflow meter with contact cleaner
Old Sep 9, 2007 | 09:30 AM
yushinrt's Avatar
and no engine light funny things is that it only happens ofter 90c
Old Sep 9, 2007 | 09:44 AM
StealthTL's Avatar
Metatron
wot iz 90c
Old Sep 9, 2007 | 10:00 AM
zaku's Avatar
車の性能の違いが戦力の決定的差ではない ということを
Did you experience stall during idle and need repeat stepping the accelerate pedal?
If yes, clean the throttle body and the problem go away
Old Sep 9, 2007 | 10:05 AM
yushinrt's Avatar
no i haven't stalled yet it sounds like it going to but it doesn;t lol.
what i want to know is that why does it make funny noise from the engine after the temp hits 90Celsius(oil temp) that is why i thort it could be the seal or the cat.
i am not to sure i am taking it to a dealer tomorow see what happens and there and i am not to sure about brown motor because it doesn;t do it a t low temp and makes no noise idels fine and engine check light never been on eather.
Old Sep 10, 2007 | 01:06 AM
yushinrt's Avatar
just got the car from dealer they recon nothing was wrong in my car. at that time bullshit so i took it for a drive and nothing it just drives normal.
what the **** ay what i want to know is that what the hell was that sound that coming from my engine
Old Sep 10, 2007 | 12:47 PM
blacxicano's Avatar
I have the same issue with my car at times. When stopped it idles fairly rough, and this week it stalled on me. Started the car back up and everything was fine. I notice that it only does it on warmer days (but its not consistent) but it does it once but then everything is fine. Everything is stock. The idle gets pretty rough. Im hoping to get into the dealer this week
Old Sep 14, 2007 | 06:10 AM
yushinrt's Avatar
blacxicano did you goto the dealer ??
Old Sep 14, 2007 | 11:05 AM
blacxicano's Avatar
work has had me flying out all over the place. I am hoping to take it in today.
Old Sep 14, 2007 | 12:13 PM
Clavius's Avatar
Its all about Style...
Could be your CAT. I had a similar experince where there was just no get up and go. At times I've read and heard it doesnt throw a CEL right away. Mine only threw a CEL once it finaly became clogged up completely.
Old Sep 14, 2007 | 12:18 PM
tajabaho1's Avatar
Destroying Threads
dead cat.
Old Sep 14, 2007 | 03:38 PM
yushinrt's Avatar
dead cat ?? i want to know what it is ay because the stupid mazda can't find any thing and they look at me like a dumb *** lol i had the car for 2 years now !!! i know when my car is not running right. how can you find out if you have a dead cat or not ??
Old Sep 14, 2007 | 05:13 PM
Brettus's Avatar
Boosted Kiwi
give it a kick . If it stays still its dead . Sorry yushi - could not resist ....
Old Sep 14, 2007 | 07:46 PM
tajabaho1's Avatar
Destroying Threads
lol, well, according to your symptoms, it looks like your cat is about to die, in other words, its almost clogged, for some reason the CEL wont show until its really dead
anyhow, you said u hit the throttle like crazy and nothing happens for a while sounds like it, if u do someday hit the throttle and nothing happens at all, then your cat is dead
Old Sep 15, 2007 | 12:51 AM
Clavius's Avatar
Well sadly techs are well just that techs. All they do is type up symptoms on a friggin' pc next to a lift and pray that some form of TSB is avilable. They had my car for 3 days before realizing it was my CAT. Mind you I knew right away (after posting on here of course) and told them on the 2nd day but was blown off. As you said you know what your car sounds and acts like, sadly the tech's never take that into consideration especially since its a rotary engine and half the techs never deal with 'em at all.
Usualy a dead CAT results in low milage (8-13mpg avg for me), slow to no responce when gas pedal is pressed down fully, that and your exhaust note will be off by a little bit, best way to describe it is that its off by a frequency hard to describe in words really lol. Recommend they take a look at the CAT stating that several owners have had theirs replaced with similar symptons (some of us on here are on their 3rd CAT I believe if not 4th).
Old Sep 15, 2007 | 06:20 AM
yushinrt's Avatar
thanks for your help everyone.
i think i am going to get custom made cat ay.
Old Sep 17, 2007 | 03:30 PM
blacxicano's Avatar
I am dropping off the car tomorrow morning at 8 at Hiley here in dfw. I will let you guys know what they say.
Old Sep 18, 2007 | 02:00 PM
blacxicano's Avatar
Just got off the phone with Mazda they havent gotten to my car yet, they are about to start on it. They are going to run a compression and vacuum test on it. Going to go get the rental car right now.
Old Sep 18, 2007 | 11:41 PM
dry apex seals..
premix to mask the problem. damage is done..
Old Sep 18, 2007 | 11:42 PM
[QUOTE=tajabaho1;2054759]lol, well, according to your symptoms, it looks like your cat is about to die, in other words, its almost clogged, for some reason the CEL wont show until its really dead
anyhow, you said u hit the throttle like crazy and nothing happens for a while sounds like it, if u do someday hit the throttle and nothing happens at all, then your cat is dead[/QUOTE
stop. please..
you dont know what you are talking about..
Old Sep 19, 2007 | 12:07 AM
tajabaho1's Avatar
Destroying Threads
I never do swoope, I never do :D
