View Full Version : 04 Dyno Results
BranDaMan
09-08-2007, 11:36 AM
I just got my 04 6mt 8 dynoed this morning and I wasn't very impressed but I wasn't disappointed either. My only mods are K&N short ram intake and Racing Beat Cat Back. I dont have a scanner so i cant post the graphs. sorry maybe when i get to school monday i can post them up...but here are the numbers...
179.2whp
135.9wtq
And my air/fuel ratio was hoovering around 12 which i think is normal.
The guy doing the dyno told me that he had done a stock 04 6mt a few months back and he got...
171.9whp
132.2wtq
So i figure i picked up about 8 whp with my mods. Not great but I guess pretty normal for the 8.
So do my numbers sound about right? The guy doing the dyno said he could tell that i needed new plugs and wires by how the car was pulling on the dyno.
Which is true b/c im at about 27400 miles and im still on my first set, i was planning on changing at the 30k maintenance. Im pretty sure i'll pick up a few hp from the new plugs and wires.
TeamRX8
09-08-2007, 12:27 PM
What brand of dyno? Makes a difference ...
BranDaMan
09-08-2007, 12:42 PM
DynoJet
124Spider
09-08-2007, 04:47 PM
Corrected or uncorrected (for atmospheric pressure, temperature and humidity)? Uncorrected numbers are virtually useless (even more useless than corrected numbers from different dynos at different times).
BranDaMan
09-08-2007, 11:15 PM
sure...about 85 degrees and it was pretty humid.
124Spider
09-08-2007, 11:56 PM
They should have given you raw numbers, and numbers showing the equivalent for the standard temperature, pressure and humidity. Giving you uncorrected (raw) numbers, without normalizing for variables, is essentially worthless.
TeamRX8
09-09-2007, 11:35 AM
Mustang and Dynojets usually display corrected numbers
Dynojets usually indicate about 10% higher than a Mustang, but all dynos are not created equal as even within the same brand/model there are slight differences in indicated outputs
http://www.rx8club.com/showpost.php?p=2009993&postcount=229
124Spider
09-09-2007, 12:52 PM
The printout for a Dynojet will say whether it's corrected or uncorrected.
olddragger
09-09-2007, 06:25 PM
youre car is fine man--new coil and plugs could possibly give you 10-20 more hp on the top end.
olddragger
joshk118
09-09-2007, 06:30 PM
olddragger
are you serious? 10 to 20 hp from a coil and plugs? my car is at 49k miles, would i get those results from replacing my ignition system components? im talkin about a new coil, new wires, and new plugs
Brettus
09-09-2007, 06:35 PM
agree with OD if your peak hp is way below 8500 - that it is most likely a coils problem
olddragger
09-09-2007, 06:43 PM
yep-it has been shown many times.
OD
AcidAngel7477
09-09-2007, 10:04 PM
where did you get it dyno'ed?
:AA:
TeamRX8
09-09-2007, 10:58 PM
olddragger
pretty bold prediction given the lack of data to support it :confused:
dmp
09-09-2007, 11:48 PM
179.2whp
135.9wtq
171.9whp
132.2wtq
There's no way you know if your mods made ANY HP. without a baseline run of YOUR car, there's a chance your mods REDUCED Your HP.
MY Car, on a dynojet, stock, made 186whp. That'd mean your mods 'cost' you a few ponies.
Get what I mean?
BranDaMan
09-10-2007, 11:00 AM
:AA:
Colvin Automotive Austin Tx
BranDaMan
09-10-2007, 11:04 AM
Get what I mean?
I was just making a PREDICTION since both cars were dynoed at the same place and were same year and had almost same mileage. Mine only with RB exhaust and K&N Intake. Maybe they did make me lose 7 whp.
dmp
09-10-2007, 02:01 PM
I know it's a 'prediction' but what I'm saying is 'Don't predict if you're worried about accuracy.'
I've seen 7-10hp difference between like cars, on the same dyno, on the same day. That's all.
As far as the RB Exhaust? Count/hope-for 1-4hp, peak, gain. For the K&N? I think you'd actually be lucky to have not lost power. Not hatin'...just from my experience reading the forums. :)
Regards.
