CEL: Running Too Rich problem... need help
Old Sep 7, 2007 | 08:06 PM
Renesis Menace's Avatar
Angry CEL: Running Too Rich problem... need help
Ok well i own a 2004 6spd on 36,200 miles and the only modifications done to it is synthetic oil(which would it affect the drive?) and a custom cold air intake that leads to my rotor symbol. it was done very well. its full 3in mandrel bent and has the 2 mesh screens in also. i will post pics up of it in the am to give a full view of it. I havent done my spark plugs yet and would that make it run rich? i doubt it but im not too familiar with the rotory and just know some things on it. Any idea why its running rich other than the intake. it ran very well for about a day also. need the help. oh ya...it doesnt stall out or anything either like other people who have that problem thanks!
Old Sep 7, 2007 | 08:27 PM
RPIRX-8's Avatar
Apexing at Oak Tree
1. If the airflow over the MAFS is uneven it could cause the sensor to improperly read the airflow and make the car run rich
2. Might want to try and hook up a datalogger and see what the AFRs are across the rpm range.
3. What is the code that caused the CEL?
Old Sep 8, 2007 | 12:14 AM
if you have 36k miles on a set of plugs. yep that is likely your problem.. one or two might not be firing..
and the cel is what?
would that cause a rich condition??? yes i think so.. take the time to check the wires and coils while you are at it..
hint, few get 25k miles out of the plugs..
Old Sep 8, 2007 | 12:31 AM
MyNam3IsM33TBALL's Avatar
as far as i know rx-8's don't take/need synthetic... =P
Old Sep 8, 2007 | 04:17 AM
wow,
just wow...
Old Sep 8, 2007 | 10:14 AM
RPIRX-8's Avatar
Apexing at Oak Tree
search much?
Old Sep 8, 2007 | 10:28 AM
Easy_E1's Avatar
Hence the moniker.
Old Sep 10, 2007 | 04:44 PM
sorry i havent had the time to get the code. ive been busy working on my chevy truck. but im going to buy the plugs this week change them and reset pcm fast and see if anything. i will get code also tonight. but i have the feeling its the plugs as its been gettin weak in power. hard to find the plugs around here... 8 stores so far and no luck.
Old Sep 13, 2007 | 06:46 PM
Well the code came out to be P0172. Whats this mean?
Old Sep 13, 2007 | 06:58 PM
Jon316G's Avatar
Grasshopper
P0172 = System too rich ON 2 Fuel system
Old Sep 13, 2007 | 07:51 PM
blah blah blah
Old Sep 13, 2007 | 09:07 PM
so spark plugs havent been changed at all at 36,000 so could this be it? or does anyone have a better explanation to this? thank you
Old Sep 14, 2007 | 01:38 AM
Jon316G's Avatar
Grasshopper
One thing I usually tell people is if they have an issue (that is possibly sensor related) its a good idea to reset the KAM first before you go out and spend money (plus it only takes a few seconds to do).
Now this code could be caused by:
1) A malfunction with the front O2 sensor
2) An issue with the pressure in your fuel line
3) A malfunction with the fuel pump itself
Like I said, reset to KAM first to see if it clears the CEL (I usually unplug the battery first, then reset the KAM). If it still occurs, take it to Mazda (though they might try to blame the CAI).
Old Sep 14, 2007 | 02:42 AM
read the 3rd post in this thread.
Old Sep 14, 2007 | 03:32 AM
Jon316G's Avatar
Grasshopper
Swoope:
If it were spark plug related, wouldn't he get misfire codes (P0301 or P0302)?
Not saying that you're wrong because I thought about it being the spark plugs too, I just figured that misfire codes would come first.
beers to you too
Old Sep 14, 2007 | 03:41 AM
Originally Posted by Jon316G
Swoope:
beers to you too
not really,
i have had those codes with new plugs and old plugs.
the order..
plugs
wires not connected tight. might cause a misfire.
coils..
but 36 k miles on a set of plugs is silly... simple first.. and likely not driven hard enough to keep clean...
i have had a misfire code caused by low fuel...
Old Sep 14, 2007 | 03:50 AM
Jon316G's Avatar
Grasshopper
Interesting! Thanks for the clarification.
I agree that 36k miles is a long time without changing your spark plugs. I beat mine down 'till 28k miles.
Old Sep 14, 2007 | 04:22 AM
Flashwing's Avatar
3-wheeler
Yikes! I'm at 36,000 miles on the stock plugs. I guess it's good I'm changing them this weekend. No problems to report thus far.
Old Sep 14, 2007 | 12:30 PM
zoom44's Avatar
can we get a picture of the placement of your maf sensor in your intake tube?
thanks
Old Sep 19, 2007 | 05:43 PM
^ Your right, if the changed the intake tube and MAF location...................
Post a picture.
I got 14k on my plugs. Looked good but It was time to replace.
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
