Flashing CEL after Pulley's and Plug wires???
Old Sep 1, 2007 | 10:17 AM
rx8guy86's Avatar
Drive Like you stole it
I started getting the car ready for the RX8BOTD on wednesday. Yesterday I put the Unorthodox pulley's and RB Plug wires back on the car. Got the car back together. Started up Idled fine... When I left the shop i noticed the flashing CEL. If the car is idling, there is no CEL, But as soon as you get the rpm above 3k or so, it starts flashing. I haven't had time to work with it since. Any Ideas or recommendations? Thanks in advance.
Old Sep 1, 2007 | 10:29 AM
Nopstnz's Avatar
Hmm, I had a flashing CEL for a couple of days after the agency power pulley install. I did that thing where you reset the ecu by tapping the brake pedal like 20 times in 8 seconds and it went away. Maybe try that? Or I hear there is one where you turn the steering wheel all the way to the left and right a couple times and that does something, I can't remember what though
Old Sep 1, 2007 | 10:40 AM
rx8guy86's Avatar
Yeah, turning the steering wheel back and forth resets the Trac control... Whats strange is that the first time I had the kit on the car, I had no problems...
Old Sep 1, 2007 | 10:48 AM
magikone69's Avatar
i had this prob to, its the eccentric (sp?) shaft sensor that needs to be reset and to do this you have to unplug the bat for a few mins, then re connect and turn the car on to the acc position and tap the brakes 20 times within 8 seconds to reset it. it will be succesfully done if you see the oil gauge sweep half way and back...for some reason i had to try this almost 5 times for it to finally go away...give it a try.
Old Sep 1, 2007 | 12:10 PM
rx8guy86's Avatar
Very Interesting... i will have to try that when I get home.
Old Sep 1, 2007 | 05:28 PM
rx8guy86's Avatar
Yup, that was it. Thanks Magikone69!
Old Sep 3, 2007 | 04:11 PM
if you'd have searched you'd have seen the dozen or so threads from people with the same issue being told the same thing ...
Old Sep 3, 2007 | 11:20 PM
Where is Mugatu when we need u ?
Audio Concepts ATL
Sep 26, 2021 01:59 PM
cushing75
Nov 12, 2018 12:46 PM
uZu
Dec 30, 2015 12:35 PM
T_Mags
Sep 3, 2015 11:40 AM
