Noob ?
Old Aug 26, 2007 | 08:01 PM
Fri Guy's Avatar
Noob ?
What is this premix I keep reading about? I'm still confused. When should you use it & how. Do I use it at every fill up or what?
Old Aug 26, 2007 | 08:11 PM
Easy_E1's Avatar
Before everyone else FLAMES you, try searching.
So I did it for you.
Your welcome.
https://www.rx8club.com/showthread.p...ghlight=PREMIX
Old Aug 27, 2007 | 04:15 AM
DOMINION's Avatar
I don't buy Kool-Aid
I don't pre mix funk dat!
Old Aug 27, 2007 | 09:11 AM
New Yorker's Avatar
No modern car, driven normally (i.e., not racing) needs to have "pre-mix"—including this one. Hell, I wouldn't own a car that requires fussing around with pre-mix every time you fill-up, and few others would, either!
If, on the other hand, you're racing or drving the car very hard, it might be a good idea:
"Hitting the track? Toss in a little premix – If you're going to drive the car especially hard for extended periods of time, it is wise to add 4/6oz of two stroke oil to the fuel for extra seal lubrication. Its not required, but it’s a good safety measure to protect the engine."—RX-8 FAQ
(By the way, that "RX-8 FAQ" answers a lot of your questions: https://www.rx8club.com/new-member-forum-197/rx8-faq-new-owners-116484/)
Old Aug 27, 2007 | 02:34 PM
CTrx8's Avatar
space for rent
why do you keep starting more noob questions and even saying they're noob questions when you've been told time and time again that the info is in the sticky threads and you can search? seriously - SEARCH!!!!
Audio Concepts ATL
Sep 26, 2021 01:59 PM
maisis00
11
Apr 20, 2006 01:18 PM
mspieker
Jun 21, 2005 09:59 PM
Eradicator
RX-8 Racing
22
Dec 20, 2003 11:06 AM
