loading the springs??
Old Aug 24, 2007 | 03:19 PM
RXSeven1's Avatar
dorito spinner
hey guys, i just installed my s-techs and i followed the instructions on loading the front springs by leaving the a arm bolts loose in the front until i set the car back on the wheels. the front looks great.....
the back however looks still a bit high. are you suppose to load the back springs also? the only major bolt i removed in the back was one control arm and i tightend it before i set it back down. could that be the cause?
Old Aug 27, 2007 | 02:51 PM
lesper4's Avatar
T-29 years and counting
i didnt pre load my s-tech when i installed them and it looked great, not sure what the issue in.
Old Aug 27, 2007 | 04:35 PM
altspace's Avatar
Eccentric Shafting
I have the same and installed myself. You just need to preload the front. Note that the rear is only a .5" drop with the S-Techs. Also that within a month or so it will settle and be a bit lower.
Just in case anyone asks, my sig is not real.
Old Aug 27, 2007 | 05:19 PM
NgoRX8's Avatar
yea you cant do anything about the rear.
Old Aug 27, 2007 | 10:08 PM
RXSeven1's Avatar
dorito spinner
hahaha, your the reason i even brought up this topic. i knew you had stechs and im like "wtf did i do wrong!!"
Old Aug 27, 2007 | 10:29 PM
kevinD1226's Avatar
i bought tanabes and for some reason it looks like the front is higher.. let them settle then see
Old Aug 27, 2007 | 10:46 PM
dillsrotary's Avatar
jersey fresh
you should get an inlinement soon
duworm
Oct 1, 2015 04:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
drlubell
Sep 26, 2015 11:58 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
