Problem on Progress front sway bar.
Old Aug 23, 2007 | 07:26 PM
atony3333's Avatar
Question Problem on Progress front sway bar.
I just finished my front progress sway bar yesterday.
Why after put this on, it has noise when I drive on the road.
The noise is sound like something is crash with sway bar. It's Pretty lound.
But when I check the car there are still have enough space for sway bar.
And the bar is look fine and everything are look fine. But the things is I cannot find out where cause the noise, but when I drive the noise is come from the sway bar.
Did anyone know this kind problem, or anyone have this kind problem before?????
Old Aug 23, 2007 | 07:32 PM
no problem for me, sounds like an installer issue
What kind of end-links....stock??
Old Aug 23, 2007 | 07:55 PM
DarkBrew's Avatar
Extraordinary Engineering
Welcome to the forum!
Take some pictures of the bar from under the car and post them here. You should get an answer...
Add location to you profile when you get a chance
Old Aug 23, 2007 | 08:18 PM
WoodsOfGreenRx8's Avatar
Dark..
You're all a bout location. Thats like the third or so time past couple of days I've seen you ask about that. heh
anywho
Sounds like you might be rubbing your sway bar against the endlinks?
Old Aug 23, 2007 | 08:25 PM
DarkBrew's Avatar
Originally Posted by WoodsOfGreenRx8
Dark..
Must be a Canadian thing...
Old Aug 23, 2007 | 10:51 PM
atony3333's Avatar
Stock
Old Nov 9, 2008 | 06:07 PM
Ranx0R0X's Avatar
Get that loose screw...
Groaning....
Yeah, I know this is an old thread but...
I had some AP sway bars installed. The front started to squeak some and gives a groan when going over speed bumps. I can create the noise by jumping up and down while seated on the front fender. Interestingly the noise is pronounced on the way UP and not on the way down.
...Stock links.
Old Nov 9, 2008 | 06:20 PM
Silicone grease on the bushings
Old Nov 9, 2008 | 06:23 PM
Ranx0R0X's Avatar
Grease...
I took it back to the garage where it was installed and they put some "lithium grease" on it but that hasn't helped. Should I go back and ask for silicone?
Thanks for any help.
Old Nov 12, 2008 | 08:53 AM
Ranx0R0X's Avatar
Took it back to the installer and they removed it and re-installed. I suspect they didn't put in enough grease during the install but don't know. It's quiet now though which makes me happy.
xAgyex
Jun 3, 2026 03:47 PM
Billy Marcial
Mar 1, 2018 06:50 AM
Solidtrance
22
Sep 4, 2015 12:47 PM
MarkX
Jul 31, 2015 07:50 AM
AussieGray
Jul 16, 2015 03:58 AM
