Tanabe or Progress sway bars?
Old Aug 22, 2007 | 04:20 PM
trustbuddy's Avatar
help me choose.
the tanabe is F/R 30.4/20.4 inches.
the progress is F/R 32/19 inches- adjustable.
Old Aug 22, 2007 | 05:40 PM
nelsonrx8's Avatar
im looking to buy sway bars as well and im lost
Old Aug 22, 2007 | 06:51 PM
https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/sway-bars-109096/
Old Aug 24, 2007 | 01:26 PM
trustbuddy's Avatar
so, teamrx8, i assume you're for the progress?
Old Aug 24, 2007 | 01:34 PM
NgoRX8's Avatar
i was in this predicament as well. i went for progress because of price and adjustability.
there was immediate difference, and i already had coilovers too. the ride quality wasn't changed too much, though might be because i have front on soft and rear on stiff to help my staggered setup.
i have noticed that the stiffness of the bar causes my front wheel to tuck more.
i only know this because it caused me to scrape my front bumper going up my driveway. lol
Old Aug 24, 2007 | 01:47 PM
zoned's Avatar
rotary user
Save your money and buy a set of racing beats with the endlinks. leave the rest of the suspension alone.
Old Aug 24, 2007 | 02:57 PM
nelsonrx8's Avatar
im waiting for my progress swaybars to arrive hopefully in 3 days
Old Aug 27, 2007 | 07:15 PM
if you want to save your money then buy the Progress Technology sway bars, which cost less than RB and are stiffer, and use the OE endlinks ...
Old Aug 28, 2007 | 12:09 PM
trustbuddy's Avatar
TeamRX8, what is the advantage to using OE endlinks? I understand that just because something is aftermarket or labeled "high performance" does not mean that it is necessary better than OE. Enlighten me on this matter. Thanks.
Old Aug 28, 2007 | 12:11 PM
NgoRX8's Avatar
the advantage is... that they still work with aftermarket sways. you save money. by all means you can go get new ones if you want though.
Old Aug 28, 2007 | 06:49 PM
chickenwafer's Avatar
Nope
The mounting holes for the RB sways are 12mm- designed to work with their endlinks, the stock size is 10mm- so you HAVE to get new endlinks if you get the RB sways. The Progress sways have a 10mm hole so you CAN use the stock endlinks if you WANT, but you can upgrade to aftermarket links (even the RB links if you want to bore out the whole)
Old Aug 28, 2007 | 07:01 PM
try again, from the RB website:
Note: The reason that the RB sway bar is provided with a 10mm hole is to allow use of the stock OEM endlinks. If we supplied the RB Sway Bar with a larger 12mm hole, then it would become mandatory to use the aftermarket links. Although the use of the RB Endlink Kit requires minor modifications, the rather cheap “insurance” offered by the installation of this kit is well worth the modest installation effort.
However, I used the OE endlinks on the RB bar that was drilled with the larger 12mm holes without issue too (before getting the PT bars), the larger hole size doesn't matter if you tighten them properly
Old Aug 30, 2007 | 11:18 AM
nelsonrx8's Avatar
i went to a shop they said 150 bucks install what cha think
Old Aug 30, 2007 | 11:21 AM
NgoRX8's Avatar
I think you should do it yourself.
Old Aug 30, 2007 | 11:26 AM
nelsonrx8's Avatar
i think i will try
Old Sep 1, 2007 | 09:58 AM
PhotoMunkey's Avatar
Get the Progress Technology sways... They come with excellent instructions except... you don't need to remove the "undercarriage tray" from the nose. If you disconnect one of the front steering tie rod ball joints, you can get the old anti-roll bar to slide right out and the new one to slide in without removing the tray. I have these bars and did just that. They work great!
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
duworm
Oct 1, 2015 04:57 PM
Trekk
12
Sep 25, 2015 03:08 PM
Steve Dallas
Sep 19, 2015 09:39 AM
