Do you have to remove bumper to replace headlight assembly?
Old Aug 19, 2007 | 09:17 PM
architect's Avatar
I just bought a new RX8 and they need to replace the driver side headlight assembly due to a big stain in the plastic. They've ordered the new headlight but they said they'd need to remove the front bumper to replace it. Is there any way around this? Can you do it through the wheel well by removing the wheel and plastic trim? I'm very reluctant to letting a dealer tamper with the front end. I know they'll screw something up.
Old Aug 19, 2007 | 09:28 PM
yes
Old Aug 19, 2007 | 09:30 PM
architect's Avatar
yes, you can do it through the wheel well or yes, you need to remove the bumper?
Old Aug 19, 2007 | 10:00 PM
Yes...you need to remove the bumper. The headlight retaining bolts aren't accessable from anywhere else
Old Aug 20, 2007 | 05:55 AM
chrism's Avatar
Misfit Moderator TnC
the retaining bolts are about 2 inches under the lights (3 if i remember correctly) (2 under light and one under clear corner)...i wouldnt worry about the front end....its easy to take off and put on.....i would worry more about them putting your headlight in and making sure the auto leveler works properly
Old Aug 20, 2007 | 11:23 AM
NgoRX8's Avatar
correct, you need to take off the front, but it's not all that hard.
Old Aug 25, 2007 | 08:02 PM
DOMINION's Avatar
I don't buy Kool-Aid
^Right but don't drop them small a$$ screw's or you'll be like me with ducktape holding up your lights lol
rotorocks
47
May 11, 2016 03:23 PM
GracefulShanks
Aug 18, 2015 11:40 AM
TheAlbinoRhino
Aug 4, 2015 09:48 PM
Jazzmeson
Jul 31, 2015 01:47 AM
mazdaverx7
Jul 21, 2015 07:31 PM
