Inexpensive performance tips please?
Old Aug 10, 2007 | 07:20 AM
madkeen73's Avatar
Hi all.
I just joined up to this forum this week as I think I am finally going to concede my 10th Anniversary MX5 for a new RX8. My one and only reason is to get back seats! By the way, this forum has been AWESOME for iofo!
Took my first RX8 test drive today and really liked the car, but was slightly underwhelmed by it's power. Somehow didn;t feel any quicker than my MX5!?? Nevertheless, it ticks lots of other boxes, and not many other cars in the price range do.
Can anyone suggest some not-too-extreme ways of getting more power out of an RX8..without voiding warranty, or spending a fortune? After having quite a few car's with exhaust systems, i'd prefer not to get this one too loud if possible. I don;t want to be paying for supercharding/turbos. Maybe a chip or something I'm afraid I'm not to mechanically minded. Any suggestions...please?
I live in Brisbane. Are there any RX8 specialist workshops?
ta
Old Aug 10, 2007 | 07:46 AM
expo1's Avatar
He's as bad as Can
This topic has been discussed over and over. There are no inexpensive ways to increase power that Mazda has not already put into the car. Here is a link to the same question from last week
https://www.rx8club.com/series-i-tech-garage-22/performance-123475/
Old Aug 10, 2007 | 08:37 AM
takahashi's Avatar
welcome to be family mate.
expo is right. Same as the MX-5, RX-8 has the same issue. You can do exhaust and intake, it aint going to do much.
You have to spend. There is no single mod doing magic.
Edit: Expo and I have very similar category of mod... that has been guided by trailed and error by the people around here.
Drop in filter.
Flywheel clutch
muffler
Spark plug and cord, some earthing.
Tune by expert to knows your mod
Old Aug 10, 2007 | 08:52 AM
rotaryPilot's Avatar
Well there is not such a tip for increasing performance. Just consider that if there were an inexpensive modification then Mazda should have made something very wrong when building the RX-8.
I guess the most inexpensive performance mod which is not so inexpensive because it includes money for fuel , is to make more miles. It is proven as the miles increase the renesis performance also increases.
Old Aug 10, 2007 | 02:41 PM
Gomez's Avatar
Shifty Bastard.
Remove the space saver spare wheel and toss it in the back shed.
Buy a lightweight Cloth Pack....that Bose **** is heavy. So it that electric seat. And those useless foglights. Steer clear of body kits, that's just more weight and drag.
Keep your tyre pressures up.
Really, there isn't a single performance mod under ten grand worth buying.
Old Aug 10, 2007 | 02:45 PM
Brettus's Avatar
Boosted Kiwi
See my avatar - press that all the way to the floor . Works for me
Old Aug 10, 2007 | 04:29 PM
rxAMZ's Avatar
Driver training, learn to drive it better/faster/efficiently, cheap does the trick
Old Aug 10, 2007 | 07:04 PM
enforcer's Avatar
Originally Posted by madkeen73
Hi all.
ta
As a matter of interest Madkeen, are you expecting a good return on your MX5?
Old Aug 12, 2007 | 06:26 PM
dbb's Avatar
dbb
DSC Disabling Officer
Don't short shift ... then you might notice the rx8 is quicker than an mx5 ...
Old Aug 12, 2007 | 08:46 PM
Revolver's Avatar
Shootin' from the hip
Lose weight...
Old Aug 13, 2007 | 03:51 AM
DrewMan's Avatar
Culpam Poena Premit Comes
youre better off doing the suspension upgrades rather than engine mods
and maybe a flywheel/pulley combo to give that tiny bit of extra pull
Old Aug 15, 2007 | 05:39 AM
e5cape's Avatar
mod
lighter rims and better tyres
e.g this http://www.trademotion.com/partlocat...catalogid=3987
Old Aug 15, 2007 | 06:39 PM
Revolver's Avatar
The OEM rims are actually pretty light for a factory unit.
Of course you can do better but it is quite a few dollars for only a marginal gain.
I also think the stock tyres are pretty good for grip but get noisy when they wear a bit. After that, agreed that there is better rubber out there.
Old Aug 15, 2007 | 10:51 PM
labrat's Avatar
Although initially I had doubts, I am starting to come round to the point of view that running 98 or even 100RON fuel does give you a little extra in performance, and slightly lower fuel consumption. That, and the fact that my car has done 70k km, so it is starting to be run in.
Old Aug 17, 2007 | 12:09 AM
madkeen73's Avatar
Thanks for the feedback guys. Sounds like there's no cheap fix. That's ok...I think I'll wait to get used to teh stock car first anyway.
ta
Old Aug 17, 2007 | 10:42 PM
yiksing's Avatar
the giant tastetickles
I believe RON doesnt make any power difference unless tuning is done to make use of the slow burning properties of the fuel.
Old Aug 17, 2007 | 11:38 PM
erx8s's Avatar
If the above advice doesnt work for you get the .......EVO X
Ben
Old Aug 18, 2007 | 12:42 AM
enforcer's Avatar
Ben, we need an EVO like a hole in the head....and the chicks don't dig the ride
Old Aug 18, 2007 | 01:13 AM
erx8s's Avatar
Trevor
Have you some statistics to confirm your theory re-chicks and EVOS
Ben
Old Aug 18, 2007 | 02:15 AM
labrat's Avatar
Do you believe or do you know? Is it necessary to re-tune the Renesis to make best use of fuels of different RON? Can evidence be supplied to support this point of view?
I consider Gomez' advice to be the best put forward on the subject to date, i.e., keep the weight down on the car. It does seem incongruous that Mazda has a "not one gram more" design philosophy, and then punters bolt on all sorts of heavy, ricy cosmetic stuff. I must get around to doing the maths sometime to quantify the effect, but the fact is that every kg added to the mass of the car (including the driver) detracts from its performance. Gomez' advice is easy and really cheap to implement.
Old Aug 18, 2007 | 07:13 PM
enforcer's Avatar
Originally Posted by erx8s
Trevor
Ben
No...but this blows both of our theories out of the water...sound on
http://video.google.com/videoplay?do...55829449987448
Old Aug 18, 2007 | 10:49 PM
DrewMan's Avatar
parking would be a thing of the past.
it would be pretty hard to carry 1 and a half tonnes in your handbag though
Old Aug 19, 2007 | 10:17 PM
matt13b's Avatar
Gomez,that is my exact way of thinking and I have been trying to explain it to all my other car friends since I got the rx8.I got the cloth pack simly because I wanted the car to have optimum performance.I could not see how leather extra eakers,foglights,electric seat motors and the rest were going to help my performance,bodykits&wings just add weight(as do bigger wheels).These are all fine for someone who just wants to drive from a-b but if you want the most from the car remove the spare wheel and get the base model! Finally I know i'm not crazy or at least we both are..
Old Aug 19, 2007 | 11:27 PM
Gomez's Avatar
Shifty Bastard.
The RX-8 is often criticised for it's perceived lack of power. In the main, the critics are turbo RX-7 drivers or Americans (or both).
It has a sufficient amount of traffic light GP horsepower as far as I'm concerned. The RX-8 isn't a drag queen, it's the king of corners. Many critics miss that point.
In early 2004 I was looking for a new car. Being a lifelong Ford V8 owner, I considered the Falcon GT, the XR8 and the XR6T. I wanted a four door car that handled, had sufficient poke, and looked good in my garage.
I test drove the XR8 and the XR6T and was unimpressed by the build quality, handling and (surprisingly) the performance. These are heavy cars. They didn't feel any faster than my automatic 1994 EF Falcon XR8. I put the purchasing decision on hold while I pondered what to do next.
While on holiday up on the Gold Coast, I happen to see TV footage announcing the RX-8 as Wheels Magazine 2003 Car of the Year. I read the Feb 2004 Wheels cover-to-cover on the flight back home. Cut to the chase....I buy an RX-8. It's over 450kg lighter than a BA Falcon 5spd man XR8. That's nearly half a tonne.......!!
Every kilo carried affects the cars performance. I maximise the performance, handling (and fuel economy) of my cars by lightening the load wherever practicable. I don't carry spare wheels. FWIW, the Leather Pack RX-8 is 16.5kg heavier than a Cloth Pack. Part of that weight increase is offset by the corresponding reduction in weight of the LP owners wallet though.... .
Cheers
Old Aug 20, 2007 | 06:46 AM
zoom3's Avatar
How about filling the 60 litre fuel tank no more than half full. That's a minimum weight saving of 30 kg. And it doesn't cost anything. In fact it saves you money
