seems as if i lost a little power
Old Aug 10, 2007 | 05:41 AM
whoneedspistons's Avatar
well as the title says i have lost a little power in the rpm band over the last few months... after speaking with someone who is extremely knowledgable we thought that the butterfly(or valve or whatever) was not opening for the last two ports in the intake manifold... any one have any idea how i can test that to see if its opening or not?
the motor is in good shape, great compression, wasnt beat on untill 16,000 miles on it, oil changes when its suppose to, overall a well oil machine...
the diagnosis seems to make sense since it feels like there is plenty of torque (for a rotary) but dies at 5000 rpm...
Old Aug 10, 2007 | 07:00 AM
staticlag's Avatar
The Professor
coils or sparkplugs
Old Aug 10, 2007 | 07:09 AM
nah man.. they have been checked... its deff feels like its only running on 4 ports
Old Aug 10, 2007 | 07:49 AM
r0tor's Avatar
everytime you turn the ignition the valves get a diagnostic check based on the position feedback... if it determines its stuck you get a CEL
probably a burnt coil is a better bet
Old Aug 10, 2007 | 08:04 AM
wow... thanks... nice response guys
Old Aug 10, 2007 | 08:06 AM
mysql101's Avatar
I would also say check the coils and spark plugs.
I ran the greddy EMU turbo kit with the intake block for a few months - which blocked off two of the intake ports making me a 4 port, and there was no significant change in the way the car performed.
Old Aug 10, 2007 | 12:47 PM
305WANKEL's Avatar
start with the sparks and coils- and then check the cat- but im guessing if you get a clogged cat you'll get a cel ( im not sure )
Old Aug 10, 2007 | 12:51 PM
mysql101's Avatar
Why has nobody mentioned the "clogged cat" issue?
hehe. Good point. I neglect that one since it's of sight, out of mind.
Old Aug 10, 2007 | 01:47 PM
my cat is in the garage
Old Aug 10, 2007 | 11:20 PM
305WANKEL's Avatar
look , i had a test pipe with a resonator ( home-made ) and i was losing a lot of power in the high rpms- put the stock cat back in and all the power came back - if you have a custom made resonator , you should probably check that
Old Aug 11, 2007 | 02:54 AM
you would get a cel if the ssv valve was not opening or working in the test...
gummed up valves would be a cause.. the second ones might not be opening fully or the third set, same thing.. but i would swap coils and add some 44k and run the crap out of it...
pm me...
Old Aug 11, 2007 | 05:38 AM
mikeferz42's Avatar
13BEAST
sounds about right...clogged cat = CEL. 'butterfly' not opening would cause hard start ups also wouldn't it?
i had this problem with my old car and it was the ignition coils. same with my friends 02 1.8t gti.
Old Aug 11, 2007 | 05:13 PM
the problem occured when i had the cat on the car and its the same since i have swappeed to a mid pipe.... i am going to check the coils this weekend and do the test to see if the butterfly is stuck shut
Old Aug 11, 2007 | 07:26 PM
Brettus's Avatar
Boosted Kiwi
https://www.rx8club.com/rx-8-discussion-3/no-more-power-loss-124221/
worth a crack .....
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
p8ntman442
Sep 23, 2015 09:18 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
