Dudewtf./Possible heat issue.
Old Aug 8, 2007 | 05:29 PM
Shini's Avatar
You set my soul alight
Car is starting to act up again. Same sh** different day. This all started when it was like 105 degree's outside, since that really hot day it's been going crazy again. Over heating maybe? I don't know...It was about that hot today and was doing the same thing, car was fine until yesterday in that hot weather...what the hell is going on! Symptons are as follows:
Rough idle, delayed gear up/down shifting, loud knocking noise when idling and delayed throttle response when at a dead stop. Not to mention what feels like a loss of power.
This will be my fourth time this has happend, I've had it at the dealership 3 times before this...I'm about to go crazy
What should I do I don't want to take it back to the dealership....Because they've failed to fix it 3 times before so I don't think the fourth will be any different.
Should I take it somewhere else to have a second opinion or go up to the dealership and say "WTF MATE!"
I don't get this...what the hell is wrong with my car...You'd think after taking it to the dealership thrice it would be fixed right?
Old Aug 8, 2007 | 06:59 PM
Scott R's Avatar
Sold my RX-8 :(
Stupid questions...
- Are you giving it 91 octane?
- Have you checked the oil?
I just got my RX-8, so I'm a newbie. It's been very hot where I am, too (but probably not as hot as your experiencing). I popped the hood on an RX-8 to show some workmates. I never did that sort of thing with my old beater (a '93 Nissan Altima), so I don't know if it was normal or the hot weather or if the RX-8 runs extra hot, but the first thing I noticed was that the hood was scalding hot just to lift.
Old Aug 8, 2007 | 07:33 PM
Stavesacre21's Avatar
1.21 Jiggawatts
if the problems really are that bad, i'd be hauling to a different dealer for sure. Tell um to run a vacuum test. Engine sounds like it's about to be overhauled to me. That's pretty severe to be something very minor.
Old Aug 8, 2007 | 08:34 PM
Shinka-Dono's Avatar
mildly unexcited
Report old dealer to Mazda. Find another dealer.
Old Aug 8, 2007 | 09:43 PM
musclecarconvrt's Avatar
It's the heat Shini. Mine does it over 95 and or long cruise over 90. Report the old dealer and find a new one X2. Do your best to keep it cooler by cruising in low gear and avoid heavy traffic.
Try some of the cooling mods on the forum. like: Water Wetter; remove rear hood weather strip and replace with 1 inch rubber spacers to help air flow out of engine compartment; take control of the fans away from the ECU with an added switch.
Oh, and pray for rain to cool things down
Old Aug 9, 2007 | 09:18 AM
missinmahseven's Avatar
Glitchy Rotary Madness
this is gonna sound really weird, but have 'em check out your motor mounts.
cliffkemp
Dec 24, 2024 10:48 AM
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
DG07
Sep 28, 2015 10:58 AM
Learners_Permit
Sep 27, 2015 07:38 PM
