clutch will not disengage
Old Aug 5, 2007 | 01:58 AM
brad_93ls's Avatar
HELP... ok bout a act streetlight flywheel got the engine counderweight, act stage 2 clutch with prostreet clutch, new master and slave, bled the line, got new piolit and throwout bearing and the clutch still Will not disengage.. it shitfts but if you try to start the car in gear with just the clutch pedel down it rolls forward if you start it in neutral it starts then you put it in gear and if you hit the breaks it shuts off.. we are now lost... need help
Old Aug 5, 2007 | 02:05 AM
Easy_E1's Avatar
Did you get a new Pressure plate with this ?
Old Aug 5, 2007 | 02:16 AM
brad_93ls's Avatar
the pedel play is maxed out, its not a puck clutch there street clutch and there pressure plate
Old Aug 5, 2007 | 02:42 AM
Easy_E1's Avatar
What I'm thinking is, is there may be a height difference (pressure plate) between stock and the new clutch/pressure plate you bought. If the pressure plate is not as tall as the original pressure plate, then you may not have as much pedal travel. Thus not allowing the clutch to fully disengage.
This clutch package was made specifically for the RX-8?
Have to ask,, is your floor mat bunched up under the pedal?
Old Aug 5, 2007 | 02:52 AM
brad_93ls's Avatar
made just for rx8 at least when i called act that said its fir the rx8... and the floor is clean no bunched yo anything
Old Aug 5, 2007 | 02:54 AM
brad_93ls's Avatar
only think i havent replaced is the ruber line from were the master hardline goes into the slave hard line would a street braided line b put in instead if the factory rubber one?
Old Aug 5, 2007 | 12:06 PM
mazdatech177's Avatar
check the travel on the slave cylinder, make sure its really being actuated. if that is right then you may have a pilot bearing issue. your input shaft sticks on the bearing and it acts like a fully engaged clutch. with the car in neutral and the clutch pressed see if you can easily put it in a gear, if its difficult to do so then keep pressure on the shifter and shut the car off, if it goes into gear easily then you may have damaged the pilot bearing on install
Old Aug 5, 2007 | 12:59 PM
brad_93ls's Avatar
see i can put it into gear easlily and everything it just wants to lunge forward if you have your foot on the clutch in gear and trying to start it, like you dont even have your foot on the clutch pedal but i do
Old Aug 5, 2007 | 01:08 PM
staticlag's Avatar
The Professor
you replaced the master and slave cylinders?
im willing to bet there is still air in there.
Old Aug 6, 2007 | 07:28 PM
whenever you diassemble any part of the clutch system, including removing the slave for only pulling the tranny, you have to reset all the clutch pedal adjustments to spec per the factory manual. I've posted all those procedures somewhere on the forum before
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
