Clutch safety switch.. help!
Old Aug 3, 2007 | 11:14 PM
cjkim's Avatar
^noob
Unhappy Clutch safety switch.. help!
So i somehow managed to f' up the clutch safety switch (don't know the exact name, the thing that prevents you from starting the car without the clutch pushed in). The switch won't fully push in with the clutch fully pressed; preventing my car from starting up. So I just taped the switch down so the switch is fully in so I can get my car started.
Now my question, can this cause any problems? at least until I can go get it fixed... Thanks!
Old Aug 3, 2007 | 11:56 PM
Spinning Sushi's Avatar
I <3 Sushi
If it's the starting issue with your clutch, warranty should cover it... In Japan, you don't have to step in the clutch to start your car... I don't really see any damage from doing that but I recommend bringing it into your dealer. It should be covered under warranty.
Old Aug 5, 2007 | 11:51 AM
mazdatech177's Avatar
might get a check engine light from it. make sure that the contact pad is still on the clutch pedal. if its missing then the pedal wont fully close the switch when you press it. it should be located on the pedal where it will contact the switch when fully depressed
Old Aug 5, 2007 | 11:56 AM
StealthTL's Avatar
Metatron
Disconnect the wiring harness and put a jumper wire between the contacts to permanently bypass it.
There is no trouble light or other symptom, other than the obvious "start up with clutch in/drive thru wall" thing.....
S
Old Aug 6, 2007 | 09:38 PM
cjkim's Avatar
^noob
It wasn't the contact patch. The switch was actually partially stuck halfway in, leaving the switch open even when I press on the clutch. i have no idea how it happened but it did. i just ended up playing with the switch till it finally let loose. Oh well. Thanks guys
Old May 11, 2008 | 09:42 PM
ricks_v's Avatar
had the same problem i accidentally press it with my finger, easy fix just by pulling the stick off the clutch safety switch.
but now im having another problem, everytime i press the clutch the're ticking sound on the engine and radio/ clock system just goes out when it happens..
any suggestion?
crs
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
