MS CAI installed DSC light staying on HELP
Old Aug 2, 2007 | 08:00 PM
Dracokain's Avatar
Like the wind
Recently bought and installed a mazdaspeed CAI and it sounds amazing, the only problem is that my DSC light on my rpm gauge is constantly staying on. When I turn the car on the DSC/OFF light flickers a few times and the that turns off but the light with the little car and the skid marks behind it stays on the whole time. Any ideas on what my have caused this?
Old Aug 2, 2007 | 08:07 PM
Digital_Damage's Avatar
sounds like the flux copacitor is on the fritz, did you unplug the battery?
Old Aug 2, 2007 | 08:15 PM
Bastage's Avatar
DEVILMAN
Turn the car OFF, move the key to the "ON" position, turn the wheel clockwise fully, and then counter-clockwise fully, start the car
That should fix your problem, but If you already tried that, then it may be that the MAF was not hooked up properly. That's all I can think of.
Old Aug 2, 2007 | 09:58 PM
Proxi's Avatar
duct tape works wonders
Same thing happened to me when I installed my K&N Typhoon v.2 intake kit. The DSC light was blinking and the "slippery" light icon stayed on. This was because I had disconnected the battery during the install. So you might've done the same thing when you installed your MS CAI.
Just follow Bastage's instructions and you'll be fine. The steps he listed are also found in the car's manual, which is where I referenced the fix when the same thing happened to me.
Cheers.
Old Aug 3, 2007 | 12:24 AM
Dracokain's Avatar
Like the wind
It's fixed I just tightened the battery cables and started the car up again and it was gone so meh, thanks for the input everyone! =D
poppinparker
Aug 10, 2015 09:20 AM
Kim Jong Illest
Aug 6, 2015 02:34 PM
MarkX
Jul 31, 2015 07:50 AM
