Ground exhaust wire needed?
Old Jul 27, 2007 | 02:26 AM
User24's Avatar
What is the purpose of the electrical ground wire on the exhaust, and are there any ramifications of a loose connection? Currently my wire is hanging down and unattached. (That's how the exhaust shop left it).
Old Jul 27, 2007 | 02:38 AM
not really sure. but ~ 35k mile with my borla unattached. it has not been an issue..
Old Jul 27, 2007 | 02:49 AM
Cody Red's Avatar
always filling [the c]up
same thing here with racing beat exhaust. since it's a single outlet the left side is left alone, and i never hooked any of them back up on the right side.
Old Jul 27, 2007 | 09:57 AM
SureShot's Avatar
Yes - you want it connected if possible.
1) The O2 sensor needs a clean solid ground reference.
2) To suppress galvanic corrosion issues in the exhaust system.
Old Jul 27, 2007 | 10:08 AM
NgoRX8's Avatar
if there is a bolt/nut to ground it on the exhaust, you may just want to do it.
Old Jul 27, 2007 | 03:03 PM
been without mine for over 2 years, no issue
Old Jul 27, 2007 | 03:16 PM
dude, without it your losing like 10 lbs of torque!
Old Jul 27, 2007 | 06:41 PM
User24's Avatar
I was going to get a small steel hose clamp, the kind with a screw on it, to put around that hanger. Then I was going to attach the ground wire to the screw.
However since I was going to the exhaust shop anyway I had them do it. Unfortunately they actually welded the ground wire onto the hanger, instead of making a removable widget.
Old Jul 29, 2007 | 06:15 PM
supergoat's Avatar
I don't "smell good".
Mines not hooked up. No issues.
Old Aug 9, 2007 | 06:46 AM
SureShot's Avatar
The possible effects:
1) If the O2 signal drops even .1 volt cruise fuel economy will suffer.
2) The stock exhaust will wear out sooner but with a stainless exhaust corrosion is less of an issue.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
F51
Aug 2, 2021 04:07 AM
Stubbs
Jul 28, 2015 09:23 PM
dbarber
Jul 25, 2015 01:34 PM
