View Full Version : low pitched whistle when accelerating
sup3rbad
10-06-2003, 03:40 PM
does anyone hear the low pitched whistle when accelerating? i hear it usually when lightly press the gas pedal. i was wondering if that was normal.
mikeb
10-06-2003, 06:07 PM
that is not normal or atleast I havent heard it
Gyro
10-06-2003, 06:13 PM
I would check to make sure a vacuum line didnt detach.
Has the car always done this or is it a new noise?
Did you have a an oil change lately ( there are a few vacuum lines in the area of the filter)?
- If you just got your car, and are unfamiliar with rotaries, it might just be that lovely whine the rotors make. However I'll give you the benefit that you know its not that;)
sup3rbad
10-06-2003, 06:50 PM
hmm maybe its the rotors spinning. but i'll check if it keeps up. i hear usually when the engine isn't revving so hard and usually during 3rd and 6th gear
sohcpunk
10-07-2003, 06:50 PM
I think thats the sound of the whirling rotary engine. I can hear mine when im driving really slow around a parking lot but when your cruising at high speeds, the noise is gone because there are other road noises around.
blizz81
10-07-2003, 08:43 PM
That might just be first gear whine due to the synchros, which is fairly common for MTs as far as I know. Was what I was going to suggest, but the poster said 3rd and 6th gears.
I have a whistle-like noise that can be noticable from the Bose amps (I believe) in my car when my stereo is on. If I cut the power to the deck, it stops. One more thing to try I suppose, if the radio isn't already off.
sohcpunk
10-07-2003, 08:52 PM
I have the AT and come to think of it, it only has that whining sound in first gear.
Bolder8
10-10-2003, 11:10 AM
Mine has 100 miles on it in 4 days and I have the same noise. The whir of the Rotary is distinct but this sounds different and is only noticeable at very slow speeds. I wondered if it was "normal" as well. The radio is off when I hear it.
Magnesium
10-10-2003, 12:02 PM
After reading this post a couple of days ago, it made me listen carefully once or twice while depleting my gas level rapidly :)
I did hear a whistle type sound, I think it is the gulping for air that is causing it.
WTF no turbo
10-11-2003, 03:03 AM
Im getting same noise during hard reving in every gear.I will try to pin down the noise tommorrow but it does sound like a little whistle under the hood.
jdl
10-11-2003, 08:58 AM
Originally posted by sup3rbad
does anyone hear the low pitched whistle when accelerating? i hear it usually when lightly press the gas pedal. i was wondering if that was normal. This is an accurate description for me, too. It's pretty distinctive, too. Now over 25K, started noticing it sometime after 12K. It definitely wasn't there early on.
sup3rbad, any chance you noticed the sound only after an oil change?
Edit: "Now over 2.5K , started noticing it sometime after 1.2K ." Sorry! I didn't finish my coffee before that message!
JoeRX8ter
10-11-2003, 09:32 AM
You have 25K on your Car already? WOW, hows she doin?
Magnesium
10-11-2003, 10:02 AM
That is some serious driving.
I will have about 9K on my car when I complete my road trip in a few weeks. I will post if I have any problems.
jdl
10-11-2003, 11:27 AM
Originally posted by JoeRX8ter
You have 25K on your Car already? WOW, hows she doin? Rats! typo: I edited my post to say I meant 2.5K. Sorry to cause all the excitement ;)
sup3rbad
10-11-2003, 02:56 PM
nope, no oil change yet. i'm on 1.5 k, when should i get an oil change?
mikeb
10-11-2003, 06:50 PM
maunal says 5k
did mine at 2900
