Reducing Heat
Old Jul 26, 2007 | 01:04 AM
shaun_quan's Avatar
Unhappy Reducing Heat
Hi Bros, I'm from KL, i am searching for a way to effectively reducing the heat of my Gear Box and Navigation Console due to high power generated through the rotary engine that goes through the exhaust system, but confusing on what to change, hope anyone here can provide me the exact way on doing so.
Old Jul 27, 2007 | 11:52 PM
SE3P_HKG's Avatar
Force Fed @ 308ps
First thing you may consider is to heat wrap your manifolds and exhaust system. These will reduce a lot of the heat. Also, you can place insulation to the body of the car that get close to the gearbox.
Old Jul 28, 2007 | 09:17 PM
walt's Avatar
if you are abit adventurous, you can try this?
http://www.hi-impact.org/ryang/modif...8_console.html
Old Jul 29, 2007 | 10:25 PM
shaun_quan's Avatar
Hi, thanks for the tips bros, this definitely clear off some of my doubts, well will try on those tips provided here. Thanks a lot
Old Aug 2, 2007 | 08:25 PM
boonyloh's Avatar
Rotorhead
someone has tried installing an atf-cooler which works brilliantly....
Old Aug 2, 2007 | 09:46 PM
lennon's Avatar
It's an extra feature for winter..... But here we can keep tapau chicken rice or milo warm..... hahhah
Put a big piece of heat shield above the gearbox will do....
Old Aug 3, 2007 | 01:04 AM
shaun_quan's Avatar
Hey thanks for those tips, will explore one by one and decide which is the best practice towards this issue
Old Aug 11, 2007 | 11:38 AM
SushiFan's Avatar
I'm also thinking of installer a second atf cooler (is this the one right behind the right fog lamp position), noticed that my cup holder gets real hot after a slightly longer drive.
Old Aug 29, 2007 | 12:52 AM
munche187's Avatar
"MuNcH-E"
take the cat out replace it with a race or test pipe
Old Aug 29, 2007 | 12:58 AM
jaii13's Avatar
The heat comes from the cat.
cliffkemp
Dec 24, 2024 10:48 AM
XianUnix
Sep 29, 2015 03:48 PM
Learners_Permit
Sep 27, 2015 07:38 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
