Info on how to take out the center radio panel
Old Jul 23, 2007 | 10:59 PM
kanedrz's Avatar
kanedrz
I want to replace my cd player for mp3 player and I want to know how to take out the radio panel? First I took out the center panel (shifter panel), then the ashtray panel and removed one bolt, closet to the driver side, behind the radio. I loosen the radio panel a little but it seems stuck. This is far as I got, any info I would appreciate it.
Old Jul 23, 2007 | 11:10 PM
WikkedOne's Avatar
Deals on wheels
here is a link to the DIY thread https://www.rx8club.com/showthread.php?t=7644.html
from what i can tell your at the part where there are 2 screws at the bottom of the radio (behind the cig lighter thing) a very important step to do right now is to take off your shirt and put it over the shifter, so you don't scratch your HU
then you take your hand and grab the radio from the bottom it kind of feels like a handle in the middle - then use a gentle but firm tug to pull out the clips, they are sometimes really hard to get out but they will come. sometimes a small jerking motion helps.
Old Jul 24, 2007 | 12:13 AM
laythor's Avatar
I zoom therefore I am.
If you've taken out the dreaded 10mm bolt of doom and the two screws at the bottom then the HU should be free.
It will take firm constant pulling to pop it loose. Some people have reported their wire harnesses catching behind the radio.. so if you have a friend with small hands have then reach behind the radio from the glove box (after it's removed) to play with the wires and make sure they're not catching.
Old Jul 25, 2007 | 12:20 PM
kanedrz's Avatar
kanedrz
Thanks guys, once again. I got it done just under an hour.
nadodave
Aug 28, 2019 05:55 AM
CARBONRX-8
Oct 5, 2015 03:46 PM
FubarI33t
Sep 28, 2015 08:45 PM
CMRine04
Sep 23, 2015 09:31 AM
just1jack
Sep 9, 2015 04:45 PM
