Ultimate Wiring
Old Jul 21, 2007 | 11:28 AM
Phish806's Avatar
Ultimate Wiring
I have finally decided to purchase Emanage Ultimate and was wondering what wiring harness to purchase. Do I need the complete harness and the plug and play harness, or does the plug and play harness for the RX-8 do it all. I have searched through posts and only found ones dated from 05 and 06 so was curious how things have changed and if there is still wire splicing involved... thanks for the help guys
Old Jul 21, 2007 | 11:30 AM
mysql101's Avatar
if you buy the EMU upgrade kit, you'll get the EMU along with the harness for plug and play on the RX-8. I think it ran about $600 new for everything.
Old Jul 21, 2007 | 11:42 AM
Phish806's Avatar
so all i need is the plug and play wiring kit... i found the emanage unit for about $500.00 , but the plug and play wiring from the greddy site is $200.00. But, the $200.00 kit is all i should need? just confirming .. i do not want to buy wiring i do nto need and/or have to wait for a second order of wiring that i had not purchased. thanks for puttin up with my lame questions
Old Jul 21, 2007 | 11:46 AM
mysql101's Avatar
if you can cancel your emu purchase, it's cheaper to get both in one set.
they used to sell the turbo kit with blue, and then they changed to emu and put out an upgrade kit for $600.
people also sell the upgrade kit used for the $400 range with harness
Old Jul 21, 2007 | 11:47 AM
chickenwafer's Avatar
Nope
MOHD has the EMU upgrade with harness on the cheap. He's on vacation now but I think he's back on the 25th
Old Jul 21, 2007 | 12:03 PM
Phish806's Avatar
found a new upgrade kit for 650.00 ... sounds like this could be the way to go. but in the information about it, is says: "This upgrade kit will only work if you have GReddy Mazda RX-8 turbo kit #11540050." Does it matter that my car is N/A? will the wiring and everything still be correct? Is there still any splicing of wires?
Old Jul 21, 2007 | 09:08 PM
Why are you installing it NA? It won't work much better than the Blue...or Canzoomer mod did.......Unless you set it up to run the injectors and timing standalone it will still have the fuel trim problems the others had.............
Old Jul 22, 2007 | 09:34 AM
Phish806's Avatar
settin it up N/A jsut to get the car tuned right and not running as rich ... then the nitrous install comes... so actually i am installing it in preperation for the nitrous kit
Old Jul 22, 2007 | 09:45 AM
Phish806's Avatar
Read over the thread that GTAW posted and it sounds like people are having problems when the use the upgrade on NA applications. So i think i a will jsut purchase the ultimate and a plug and play harness... this brigns me back to my original question ... if i buy only the plug and play harness is that all i need as far as wiring goes?
Old Jul 22, 2007 | 10:10 AM
tdiddy's Avatar
Finally Boosted!!!!!!!
People are not having problems using the Upgrade Kit on NA applications but you need to rewire it. The Upgrade Kit harness is the only way you will be able to force open loop and avoid the LTFT/STFT issues that dannobre mentioned. All the wiring changes are discussed in the thread GTAW suggested. As far as I know, there is no "Plug-N-Play" harness for NA.
Old Jul 22, 2007 | 10:25 AM
Phish806's Avatar
that was pretty much the answer i was lookin for ... also the "Plug and Play" kit i was refering to is on the greddy website. It lists nothing about needing the turbo kit installed in order for it to work .. are they just assuming that if you buy the EMU that you are using it with thier turbo kit?....
Old Jul 22, 2007 | 10:45 AM
tdiddy's Avatar
Yes, 15941500 and 15941501 are designed for their turbo kit. In order to make it work for NA you will need to get 15901500 or 15901503 and rewire the PNP harness. I have 15901503 because I have my EMU in my glovebox.
Old Jul 22, 2007 | 10:55 AM
Phish806's Avatar
thats exactly what i needed to know... thanks for spellin it out for me. I have been lookin into different systems and it all gets jumbled together at times.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
tjohnmeyer
Sep 28, 2017 05:03 PM
Danield97
Sep 30, 2015 05:59 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
