help with exhaust
Old Jul 5, 2007 | 02:19 PM
alluknoskill0000's Avatar
help with exhaust
hi everyone. my friend and I are trying to install a turbo xs catback exhaust system. we are having trouble removing catalytic flange bolt. can someone who has done this mod please tell us what tools you used to remove it. also do we need a springs compressor to fit the springs back on with the turbo xs bolts in come with? we pretty much took care of everything except that cat flange bolt for the B-pipe that we cannot remove. please help! thanks a lot.
Old Jul 5, 2007 | 02:27 PM
DarkBrew's Avatar
Extraordinary Engineering
Penetrating oil and a johnson bar should do the trick.
A spring compressor shouldn't be required as the bolts are fairly long.
For my RB cat back we re-used the bolts/gasket on the Cat side. On one side the nut came off but on the other side the bolt came out. No problem either way.
Good luck.
Old Jul 5, 2007 | 06:10 PM
oh alright thanks a lot
Old Sep 8, 2009 | 02:23 AM
Eight's Avatar
Old thread but I'm having problem with the spring loaded bolt.
The nut came off on one side but the bolt came off on the other with the nut still attached.
The bolt with the nut + spring doesn't have enough length to reach the threaded holes.
I have tried clamping the bolt to get the nut loose with no luck and I've also tried compressing the spring with no luck. Is there a trick to this? or is there a miniature spring compressor that I can use while I bolt it back on.
Old Sep 8, 2009 | 03:45 PM
Eight's Avatar
Problem solved, borrowed a huge monkey wrench and with a breaker bar, snapped the nut off.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
arexatemate
Oct 28, 2019 08:16 AM
mdl0209
May 23, 2019 05:46 PM
Jb4ker96
Sep 27, 2015 10:06 PM
