dynoed over 200 hp!
Old Jul 2, 2007 | 12:32 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
dynoed over 200 hp!
we had a norcal group dyno meet on june 30th at prostreet and my dyno result was unbelievable! see for yourself! i never expected being able to hit over 200 hp NA. anyways enjoy!
Old Jul 2, 2007 | 08:07 AM
out of a few runs the highest I hit was 190 whp.. =( peterisurhero also dynoed at 200 whp
Old Jul 2, 2007 | 08:56 AM
dmp's Avatar
dmp
RX8 and a Truk....
We've got a couple ~200whp RX8's up here in the low altitude cool-temp NorthWest. IMO, and as your dyno shows, 195whp = 200whp, as the power can move between runs. What were your un-corrected (measured) numbers?
Old Jul 2, 2007 | 11:24 AM
Robbie's Avatar
What's going on with your A/F ratio?
Old Jul 2, 2007 | 01:30 PM
peterisurhero's Avatar
peterisurhero
hahah nice man! we're the same!! hahah
but now ima try to get higher hp!! i neeeeed more powerrrrrrrrrrrrrrrrrrrrrrrrr
Old Jul 2, 2007 | 01:37 PM
NgoRX8's Avatar
haha and both you guys have practically every NA mod out there.
man maybe i should start buying some more stuff.
Old Jul 2, 2007 | 02:34 PM
Ngo: or finally install that secret mod we talked about recently....
Old Jul 2, 2007 | 02:41 PM
mdw1000's Avatar
I'll snap his neck.
So which mods helped you the most?
Old Jul 2, 2007 | 05:01 PM
seems about right for your mods ...
Old Jul 2, 2007 | 05:17 PM
speeddemon32's Avatar
Bigboy in a little car!
From: In So Cal.. out in BFE... but in the good part... but not really by Cesar, Keith or Loren...
Sweet... welcome to the club!
It's funny (ok not really) how the RX-8 will pull differant numbers from car to car... dont get me wrong, I know that not every car is exactly the same, but to see ~20 differance between cars is crazy. :/
(Disclaimer: yes I realize all dynos are not the same. air temp, humidity, fuel used, milage... blah blah blah all take effect in h.p. numbers.... still ~20 - 30 h.p. differance is nuts)
Old Jul 2, 2007 | 05:36 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
yep i cant think of anything else to do except suspension and turbo... i think i pretty much maxed out NA
i think the HKS twin power and the test pipe helped the most
Old Jul 3, 2007 | 12:47 AM
Mikeluvs8's Avatar
nice!
Old Jul 3, 2007 | 12:59 PM
crimson-rain's Avatar
get the RB flash and dyno again. I'm curious to see the results.
Old Jul 3, 2007 | 01:11 PM
Rhythmic's Avatar
Laid back in the pocket
^ yeah that would pretty much max you out NA w/o getting into internals.
Old Jul 3, 2007 | 01:21 PM
thats why I want to go back. my 201 was before the flash.... now I want to go back and see the differance.
only thing is, to be fair I would have to go back when it is a 75 ish day again. its way to hot now to try. it would not be a fair comparison.
Old Jul 3, 2007 | 04:32 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
i think i saw somebody with the flash at the dyno but the numbers werent very high. if i remember it was around 180 or so. i think i will probably save money and stick with what i have right now until i go FI with the Int X setup instead.
Old Jul 4, 2007 | 02:32 PM
scremn8's Avatar
the more things change
yeah we had afew guys with the flash out here
there results were not much inspiring.
i ran mid 180's running cheap gas just to see
what i would get.. plus no prework.
Old Jul 4, 2007 | 02:46 PM
NgoRX8's Avatar
jedi54 and snowfl8k noticed the guys with the rb flash did have less dips in the powerband and a higher redline (higher top speed too).
Jst4fun
Apr 17, 2021 07:43 AM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
05rx8mazda
Nov 28, 2015 09:42 AM
