View Full Version : So dumb - Accidentally left Park Brake on :(
PatInTheHat
06-24-2007, 01:24 PM
So I accidentally drove about 1/2 mile at very low speeds with my park break on. I then started accelerating and hit around 60mph before realizing something was wrong and then noticing the park break still engaged.
How bad is this and what damage might I have caused? Anything I should do or check?
tiggerlee
06-24-2007, 01:28 PM
Was the E-brake light not on?
DarkBrew
06-24-2007, 02:07 PM
You probably didn't hurt anything but you really shouldn't do it again! You should be scanning you instruments as you drive... It's pretty hard to miss the brake light!!
NotAPreppie
06-24-2007, 04:20 PM
Wait, you didn't notice the additional drag on the car?
dannobre
06-24-2007, 07:10 PM
If it didn't smell real bad like burning brakes...you will be OK. If you cooked it really well..you might want to lube the caliper slides on the rear calipers and change the brake fluid..
PatInTheHat
06-25-2007, 10:40 AM
tiggerlee: brake light was on.
DarkBrew: Yeah I know :( Can't believe I didn't see it right away.
NotAPreppie: I was going very slow getting of of a gravel road, I didn't notice the additional drag until I started accelerating which was when i noticed the park brake.
dannobre: I didn't notice much of any smell.
NotAPreppie
06-25-2007, 01:29 PM
It doesn't sound like you had the brake on very "hard" (for lack of a better term). I'd guess you are okay, but you might want to do some preventative maintenance (lube the caliper slides, check the rotors for cracking, etc). This is one of those components that you just don't want to leave to chance.
altspace
06-25-2007, 04:23 PM
^exactly. My car won't budge with the e-brake on.
RotorManiac
06-25-2007, 04:41 PM
....I was going very slow getting of of a gravel road, I didn't notice the additional drag until I started accelerating which was when i noticed the park brake....
no worries then, I've seen a guy trying to drift his 8 with the e-brake on.... :lol: well, he managed to drift and when he stopped he found out what was keeping him back... he also managed to light up the rear brake pads too lol
