Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
Slowly, slowly making progress.
Old Jun 15, 2007 | 02:36 PM
TreyGreen13's Avatar
Slowly modding
Alright, gulf users. I now have two items on order...
Aluminum fender strakes from Rotary13b (arriving any day now)
Clear Corners from K5com in Japan. (arriving next week)
I'm going to get some stealth bulbs later, but I'm curious, what would you all recommend for my next small, relatively cheap addition? Maybe a little change to the headlights? I'd like to keep it under a couple of hundred.
Suggestions welcome!
Old Jun 15, 2007 | 02:46 PM
Slowly modding
I'm currently leaning towards putting some nice dark tint on my windows, should be able to get out under $200 that way.
Old Jun 15, 2007 | 03:20 PM
Raptor2k's Avatar
Club Marbles Member
Hey, I'm in Arlington too
These look good, I'll be ordering them:
https://www.rx8club.com/group-buy-center-85/custom-led-footwell-lights-118507/
Old Jun 15, 2007 | 03:27 PM
Slowly modding
I was thinking of doing some interior footwell lights, but I want to keep everything on my new 8 either black, white, or chrome.
Do they make that LED kit in a bright white?
Old Jun 15, 2007 | 04:18 PM
legendkurado's Avatar
i got just installed those footwells in red.. i asked him for a bright white.. but unfortunately in order for him to make white.. he'd have to buy 100 white leds.. so im pretty sure he's not going to make any other color unless there is a big demand for them
Old Jun 16, 2007 | 12:13 AM
canaryrx8's Avatar
you can get springs pretty cheap, might want to consider that as a near-future mod if cost is an issue
Old Jun 20, 2007 | 11:59 AM
Miatamoto's Avatar
Cone Killer
How bout smoking the tailligihts?
Old Jun 20, 2007 | 12:23 PM
alerx-8's's Avatar
yea tein s springs are only $160, very good mod!
Old Jun 20, 2007 | 01:29 PM
BigRed's Avatar
w8nkel
short shifter and ****!
Old Jun 20, 2007 | 02:54 PM
Slowly modding
Ok, checking back in on the thread:
Clear corners are on their way, chrome fender strakes are installed.
Next up: Legal dark window tint, stealth front turn signals, and smoked tails. I'm going to try to get these done by my next paycheck.
After that, I'm going to get springs... maybe drop it a little....
And then I can work on short shifter and other suggestions.
Old Jun 21, 2007 | 08:12 AM
CosmosMpower's Avatar
1935 lbs. FTW!
I would suggest Mazdaspeed springs or Swift. The car already has a great transmission/shifter so I don't think it's necessary to get a SS. Other stuff sounds good though. I would also suggest an Ipod cable, the Audiolink one works pretty well and sound is cleaner than CD. Takes 15 mins to install and just plugs into the back of your head unit, a local vendor TheRPMstore sells them for 115ish.
Old Jun 21, 2007 | 08:58 AM
Miatamoto's Avatar
Cone Killer
15 minutes might be a bit of an exaggeration unless you've got someone there that knows exactly where that bolt behind the dash is. If so, 15 minutes could do it.
Old Jun 22, 2007 | 10:13 AM
1935 lbs. FTW!
I can do it in under 10 now, but of course that's with the bolt out of the equation. We spent most of the time looking for the bolt on the install. Otherwise it's just unscrewing the ****, unclipping 1 panel, 4 screws and popping the h/u out to plug in the unit and reverse.
Old Jun 22, 2007 | 10:21 AM
Slowly modding
I'd have to get an iPod first. I'm not an apple fan, but it appears I'm going to have to get one to get a wide music variety in my car.
No more swapping out CDs for me.
Old Jun 22, 2007 | 11:28 AM
Keef's Avatar
the shit starter
hahaha! that's how my addiction began with strakes and clear corners... Looks mattered too me at the start but thanks too my friends who mostly own 2 seater sports cars I grew a quick jealousy too speed and didn't want too believe that an Rx-8 with everything that existed for it wouldn't be able too beat there cars.... I'm done with my NA 8...
But ya, I suggest changing all the bulbs on the exterior of your car too white LED's... I noticed that using single bulbs LED's aren't brighter, but they won't burn out and start blinking. Change the HID's too 8000K bulbs. After that it's what you think is more important too yourself... I just think that changing all the bulbs too LED's makes your RX-8 stand out more than the average stock one. I made my interior bulbs Red LED's pretty much too match the car's lighting...
Then went crazy with after market speed oriented things...
Old Jun 22, 2007 | 12:37 PM
Miatamoto's Avatar
Cone Killer
Why?!?!
Old Jun 22, 2007 | 03:21 PM
1935 lbs. FTW!
It had a 3.5mm stereo jack as well for other MP3 players etc but it won't charge it or let you change the playlist with the steering wheel/stereo buttons.
Old Jun 22, 2007 | 07:04 PM
Slowly modding
Ok, little update:
I just finished the clear corners install. I left the white bulb in the clear corners because I believe it's legal here in Texas, and I might as well keep the black/white/silver look together. (Plus, I'm lazy and didn't feel like buying and changing out new bulbs)
So, up next is tint. Does anyone have any favorite tint shop in the DFW area?
EDIT: Special thanks to the Japanese guy who ships out the clear corners, and whoever put up the DIY on the topic of installation. I got my corners in within a week, and installed in 10 minutes, was too easy.
Old Jun 22, 2007 | 07:47 PM
BigRed's Avatar
w8nkel
It may be too far for you but try ProTint on Preston and Frankford basically. They did a good job and the water should dry out quick because its the summer. Huper Optik all the way!
Old Jun 22, 2007 | 08:32 PM
Keef's Avatar
the shit starter
Why?!?!
I dunno... I figure having a bulb more oriented towards color rather than light intensity shows off looks more than practicality. I use 10000K, and don't have that big of a problem. Only time I do have a problem is when I have the chance too use my brights and they exist for that reason don't they?
Old Jun 25, 2007 | 06:05 PM
chr1s's Avatar
pwn*
I've heard very good things about ProTint as well.
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
GARCIAC951
Sep 10, 2015 07:17 PM
tgaffner
Sep 7, 2015 08:49 PM
stickmantijuana
Sep 4, 2015 10:31 PM
