FI RX8 in NZ
Old Jun 11, 2007 | 11:31 PM
Rotorpsycho's Avatar
Seen my car keys?
FI RX8 in NZ
Here are a few pics of my FI project RX8 down here in New Zealand.
This recently featured in a local car mag and they kindy sent me some of the photos. Further to that, there were some mistakes in the write up which I can seek to clarify here (I referenced this website in the thankyou section of the feature).
Specs:
2003 RX8 4 port, 5 speed manual Jap domestic model (imported to nz 2004)
Garrett GT30/40 roller bearing turbo.
Custom exhaust manifold (RE Sinclair)
Custom CF airbox (made by me)
Custom Front Mount IC
440cc primary and 550cc secondary injectors
Microtech ECU with some custom software (extra map for additional intake injector for later on.....)
Stock engine internals
Stock Clutch
Stock mufflers, custom 3" exhaust (no CAT etc)
Lowered springs and 18x5.5 DTM rims (225/40R18)
Relocated battery and new relocated washer res.
ABS, DSC and fly-by-wire throttle intact, but I do have a stubborn CEL.
Was running around 4PSI as a warmup to bigger things.
Stock it Dynoed *i think from memory* about 140 whp, on 4PSI about 205 whp.
(The % increase is the important part for me, not the ultimate peak number)
We are right this minute tuning for 8PSI. Will update figures when that is done.
I should also be able to post the charts later if anyone wants to see em.
Attached Thumbnails FI RX8 in NZ-rx8-05.jpg   FI RX8 in NZ-rx8-19.jpg   FI RX8 in NZ-rx8-28.jpg   FI RX8 in NZ-rx8-35.jpg
Old Jun 11, 2007 | 11:44 PM
rotarygod's Avatar
That's probably one of the nicest intakes I've ever seen on a turbo RX-8. Clean and to the point. The auto guys here will be interested in your car as the only 4 port we have is with the auto tranny. Nice work.
Old Jun 12, 2007 | 12:11 AM
Brettus's Avatar
Boosted Kiwi
sweet job Rotorpshyco - I remember when you started this project . How long were you off the road ?
Old Jun 12, 2007 | 12:26 AM
Seen my car keys?
Umm, around 6 months. The major hangup was the ECU part, Mazfix Australia pissed me around for several of those months....
Old Jun 12, 2007 | 12:33 AM
Seen my car keys?
Cheers. The idea was to retain and much of the standard box and filter assembly as possible. The guy fabricating the install put the turbo where he wanted it and I made up something to bridge the gap. You will see the stock air flow meter stuck in the side of it....that was before we figured out we were'nt gonna need it.
Old Jun 12, 2007 | 12:47 AM
Brettus's Avatar
Boosted Kiwi
I wondered how you would get on with microtech as no-one on here has tried it other than the Interceptor x which I believe is a specially modded Microtech .
Old Jun 12, 2007 | 02:25 AM
rotarenvy's Avatar
excellent setup! most professional looking turbo install yet!
Old Jun 12, 2007 | 05:54 AM
whoneedspistons's Avatar
looks good
Old Jun 12, 2007 | 11:53 AM
SE3P_HKG's Avatar
Force Fed @ 308ps
Very different!! Nice work.
Old Jun 12, 2007 | 11:57 AM
unreal89's Avatar
I don't mind pistons
Love the intake, just one question though:
Does a strut bar not fit? or does the 4 port not come with one?
Old Jun 12, 2007 | 02:54 PM
Seen my car keys?
It does come with one and it does fit, I just have'nt got round to putting it back on.
Old Jun 13, 2007 | 08:56 AM
MazdaJeff's Avatar
Wow, the engine compartment is really nice!
Congrats.
Old Jun 13, 2007 | 11:08 AM
pdxhak's Avatar
Official Post Whore
Clean setup. As others have mentioned the intake looks awesome!
Overall how's the car running?
Old Jun 13, 2007 | 04:28 PM
Seen my car keys?
Car has been running great. Travelled approx 5000km over 4 months with the FI setup (4psi).
Initial problems were mainly heat related, in particular in the engine bay. We solved this by hooking both fans to the microtech and kicking them in much earlier along with fitting a turbo beanie.
We almost finished tuning the car yesterday for 8psi which looks to have yeilded about 250whp peak with an extra 30whp more than 4psi in the midrange..which is really nice. The stock clutch is coping at the moment which saves me another job in the meantime.
Thanks for the comments on the intake guys, it was a lot of work but the result was worth it. Of course I have the mold sitting in my workshop and would be happy to punch out one or two.....
Old Jun 13, 2007 | 04:31 PM
rotarygod's Avatar
I'd love to see what you can get with it. There are many people here that have no confidence in the 4 port engine but I personally think it has much more in it than most think it does. I don't see any reason why you couldn't get 300 rwhp out of it. Considering the Greddy turbo has been tuned to 300 hp by a few people and it doesn't have enough flow to justify leaving the auxiliary ports working, I don't see what the issue is. The 4 port engine has more intake area than the 6 port does when it's auxiliary ports are closed. 300 should be no issue at all and most likely much higher. The ports are easily as large as the last 4 port 13B ports were.
Old Jun 13, 2007 | 04:38 PM
Seen my car keys?
Originally Posted by GTAW
I need to take some lessons from you on how to lay carbon fiber, nice job on the clean install.
Haha, yes it can be fiddly as you can't hide a poor weave layup with gelcoat.
Old Jun 13, 2007 | 04:46 PM
Seen my car keys?
300whp would be the ultimate goal and I am getting closer now. Power output is being measured on a dynojet which down here are well known for reading low numbers, I could take the car down the road and prolly see bigger numbers come up on their dyno. For instance, my batty measured 308whp or so on the dynojet but ~345whp on other dynos
I gotta say even on only 4psi the whole car was transformed and became a lot more fun to drive...which is what its all about.
Old Jun 13, 2007 | 04:54 PM
Brettus's Avatar
Boosted Kiwi
hey rotor - we gotta meet up after I get my Pettit SC installed
Old Jun 13, 2007 | 07:32 PM
mike1324a's Avatar
Need'd a Turbo
Dayum, thats awsome. And thats is the sweetest intake for a turbo ever! Mad props
Old Jun 13, 2007 | 10:53 PM
Seen my car keys?
Here is a dyno sheet following todays tuning.
Also I must apologize, I've been calling the dyno a dynojet......quite clearly its not
Old Jun 13, 2007 | 10:57 PM
Seen my car keys?
Sounds good. You come down here
Old Jun 13, 2007 | 11:03 PM
Brettus's Avatar
Boosted Kiwi
[QUOTE=Rotorpsycho;1925454]Sounds good. You come down here [/QUOTE
Never know - i just might .
How come your dyno only goes to 5500 ?
Old Jun 14, 2007 | 02:25 AM
Seen my car keys?
[QUOTE=Brettus;1925463]
The posted pull is in 5th gear and you are seeing the 180kph limit cut. If we could figure out a way to get rid of this without losing the DSC etc then we will do a pull in 5th all the way thru. Car prolly makes more power than posted as in third gear its smooth right thru...but I have no plot to back that statement up.
Old Jun 14, 2007 | 05:16 AM
Brettus's Avatar
Boosted Kiwi
if you pull out the side boot linings you can get to the wheel sensor connectors . Just disconnect them for your dyno run and you will be sweet .
Have driven on track with these disconnected . You lose DSC ABS & power steering defaults to light setting . Car is drivable but I flat spotted a trye at Pukekohe doing this so not recommended.
