bad brakes at 13k miles?
Old Jun 11, 2007 | 12:18 PM
robel82's Avatar
Yippie ki yay
I picked up my 05 8 on the 26th and 2 days after that my rear brakes started squealing. Is this normal for 8's to go thru this? It might have been the previous owners fault for maybe braking hard but still after 13k miles? I have a frontier too and never down shifted while braking. And most of the time it was under load, but I didnt have to replace the brakes until I reached 60k miles. I was just wondering if anyone else went thru this before. If there is another thread like this I apologize but i dont have time to search. Im at work.
Rob
Old Jun 11, 2007 | 12:31 PM
Sports car + High performance Brake pad = Short Pad life
This is your problem.
what do you mean by you dont have time to search you lazy ***, you have the time to typed all that and u dont have the time to search.
Old Jun 11, 2007 | 12:51 PM
kors-jan's Avatar
Bland is Boring
There is a Technical Service Bulletin (TSB) regarding the OEM brakes. Here's a link to Rosenthal Arlington Mazda website about the squeal:
http://www.mstore2000.com/PDF_Files/04-001-06-1568.pdf
My front brakes squealed LOUD at 14,000 miles. I took the TSB to my local Mazda dealer and they replaced the pads and hardware at no cost to me. No more squeal, and it's been almost a 1000 miles since then.
Oh, they may say something like the TSB is only good for cars with less than 12K miles. But if you respond nicely that the pads on a $30,000 car should last longer (like I did), they probably will do the fix -- especially if you stand there with a copy of the TSB in your hands.
When these are worn and need to be replaced (and I have to pay for it), I probably will install the the Hawk ceramic pads. But for now, this free fix using the TSB warranty was great.
Old Jun 11, 2007 | 04:17 PM
robel82's Avatar
Yippie ki yay
Thanks kors-jan. I'll try that.
Old Jun 11, 2007 | 04:23 PM
sleddog_racer's Avatar
sleddog_racer
Might help to have the TSB in hand......I had the same brake issue with my '04 @ 14k, walked into the dealership with a copy of the TSB and they fixed 'er right up and apologized for the inconvenience.
Old Jun 11, 2007 | 09:35 PM
3dartist81's Avatar
hell, i got the same issue... i'm going in to the dealer tomorrow with this pdf document!
Old Jun 12, 2007 | 12:34 PM
Nubo's Avatar
Lubricious
This does not necessarily have anything to do with the pads being "worn out". All brakes squeal -- the engineering trick is to get them to squeal at inaudible frequencies. The TSB has worked for some, but not all owners.
The problem is quite possibly NOT that the previous owner was too hard on the brakes, but rather not hard enough. Search for procedures on "bedding in" the brake pads.
Old Jun 12, 2007 | 01:21 PM
r0tor's Avatar
exactly...
and theres a fine line with performance car brakes. You use them too hard and they glaze and squeal, you use them too softly and they polish up and squeal.
Best bet is to bed them in..
Old Jun 12, 2007 | 01:54 PM
mac11's Avatar
Rotary , eh?
Or understand that Mazda used an aggressive pad compound on your car to give you great braking performance in a $30,000 street car and just live with the small amount of noise. The pads that are used to replace the "noisy" ones are not as aggressive hence to not squeal but also do not stop as well.
Old Jun 13, 2007 | 06:07 PM
j9fd3s's Avatar
yep 10kish miles on the new set here, not a peep.
drebbrnator
Dec 27, 2018 07:02 PM
RXeckless
Aug 16, 2015 12:51 PM
EfrainOlivares
Aug 14, 2015 06:17 PM
