Water Leaks - Inside!!!!!!
Old Jun 10, 2007 | 06:24 AM
TimP's Avatar
Just been out in the 8 and as I arrived home afetr driving fo about a hour I noticed water leaking from under the passenger side of the car. It stopped after turning off the engine, just going to see if it is related to the air con but it was dripping water pretty bad. Any one see this before?
Old Jun 10, 2007 | 08:02 AM
staticlag's Avatar
The Professor
What color is it? What does it smell like?
If its clear and doesn't smell like antifreeze or oil, I think its safe to say it was just the A/C doing its thing. I get this sometimes also.
Old Jun 10, 2007 | 08:06 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Define pretty bad. It's probably just the A/C. Look at it(Clear?), feel it(oily?), smell it(oil or anti-freeze?), taste it......in that order if need be. Hopefully you will stop before you get to the taste it portion!
Old Jun 10, 2007 | 08:32 AM
AQA101's Avatar
Stainless
I agree with the above answers - condensed water from the A/C. I had quite a lot of water behind the passenger seat after parking downhill on a very hot day and a longer drive.
Old Jun 10, 2007 | 08:44 AM
Mazurfer's Avatar
Inside the cabin or underneath the car? That's two different issues. Under the car is one thing, but if you had it behind the passenger seat, then it should have been wet in front of the passenger seat and probably means your evaporator pan drain plug is clogged. IF....these cars even have one, and I would assume so.......most do.
Old Jun 10, 2007 | 09:29 AM
DarkBrew's Avatar
Extraordinary Engineering
TimP, your car is okay.
P.S. Welcome to the forum.
AQA101,
We need more detail.
What year is the car: Mileage?
Colour, smell of the water.
It could be as simple as blocked drainage tubes from the AC.
Old Jun 10, 2007 | 09:34 AM
Mazurfer's Avatar
DB,
The OP I'm not worried about........that's just his A/C dripping....I'm pretty sure. I curious about the person in Germany because they imply it's INSIDE the car.
Old Jun 10, 2007 | 10:08 AM
DarkBrew's Avatar
Sorry, that was the guy I was responding to. Oops. I'll go edit it...
Old Jun 10, 2007 | 12:10 PM
Inside the car...your drain for the A/c evaporator is plugged. It is a black rubber tube on the firewall directly above the hump for the tranny.... Kinda behind the oil filter area
Outside...the drain is working normally........
Old Apr 1, 2008 | 04:03 PM
Visa's Avatar
I'm having the same issue; it's leaking what seems to be water behind the glove compartment. It also stops leaking whenever I turn the AC off.
Is this something that would be easy to unclog myself (if that is the issue) or is it a hassle to get at?
Old Apr 1, 2008 | 04:13 PM
StealthTL's Avatar
Metatron
Very easy, though hard to see.
The rubber forms 'lips' right at the top of the transmission hump in the firewall, like dannobre says, up above the oil filter.
Should be able to unstick the rubber with finger, then put grease or silicone there to stop 'em sticking together.
S
theblinkof
Oct 4, 2023 05:24 PM
Quiggs321
Sep 30, 2015 05:34 PM
He||hammer
Sep 29, 2015 09:40 PM
DG07
Sep 28, 2015 10:58 AM
