true they burn oil?
Old Jun 9, 2007 | 11:08 PM
JMaN06's Avatar
true they burn oil?
hello, i had heard these renesis rotary engines of our fellow RX8 sickness trend burn some oil..kinda like 2-stroke? is this true? they burn off some oil and its a good thing to check your oil level often? is thissss true???
thanks!!
Old Jun 9, 2007 | 11:13 PM
N rider89's Avatar
^NieL
thanks!!
yes it is true that they burn oil. its part of their natural design. it helps to lubricate the seals. its really not all that bad, all you have to do is check out the oil level about every other fill up. if its low then top it off a little. no biggie.
Old Jun 9, 2007 | 11:16 PM
staticlag's Avatar
The Professor
the oil itself is injected through an oil metering pump attached to the engine. It is not caused by a leak of any sort.
Old Jun 9, 2007 | 11:21 PM
JMaN06's Avatar
thanks for the so far input
Old Jun 14, 2007 | 07:30 PM
j0eStER's Avatar
Uhh, then I have a question. I fill it up every other day and I just checked my Dipstick and it still syas it's full...what gives then?
I ahve an 04 AT.
Old Jun 14, 2007 | 07:39 PM
supergoat's Avatar
I don't "smell good".
Your car is fine. Just keep checking it. Eventually you will see that you have to add some oil.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
RXFEVER
Sep 11, 2016 02:51 PM
superROB23
Sep 4, 2015 01:22 AM
