Problems with MS Cai
Old Jun 8, 2007 | 11:17 PM
Mort's Avatar
I got my performance package installed on my car Tuesday. Since the install the car has been running poorly in the 4500 - 5500 rpm range. No power, sort of surging. It only happens when I'm maintaining speed, or accelerating slowly in that range, if I floor it, it will run up to red line no problem. If I drive with the rpm below 4500 no problems either. Thursday morning I had a cel flash as I pulled out of the driveway on my way to work. It went out after a couple seconds.
I've done both ECM resets, no help there. I've checked for leaks and it all looks fine.
It is an 06 GT Manual
Any ideas?
Old Jun 8, 2007 | 11:28 PM
edblor's Avatar
RX-8 Taker Arounder
Perhaps a bad cat?
Old Jun 8, 2007 | 11:29 PM
Brettus's Avatar
Boosted Kiwi
check the maf is connected properly then pull it out & check it for obstruction .
Old Jun 8, 2007 | 11:33 PM
Mort's Avatar
I'll check the Maf tomorrow. If it is dirty what type of cleaner should I use?
The car only has 4000 Km on it so I can't see it being the cat, but thanks.
Old Jun 8, 2007 | 11:37 PM
Brettus's Avatar
Boosted Kiwi
CO contact cleaner or similar but DON'T touch the wire with anything !
Old Jun 9, 2007 | 12:15 AM
Electric safe cleaner.
or MAF cleaner
You can find those at ur local auto parts store for maybe 4 bucks a can, should be enough for like at 30 times of cleaning.
Old Jun 9, 2007 | 03:24 AM
https://www.rx8club.com/showthread.p...rmance+package
i have seen this somewhere..
why is this not a dealer issue?
Old Jun 9, 2007 | 10:13 AM
Mort's Avatar
It is and I've got an appointment with the dealer tuesday, but there isn't one in town so I have to catch a ferry to the city, and waste one of my days off over there. Since this seems to be a fairly common mod I figured some one may have had the same issue and found a fix.
Old Jun 9, 2007 | 06:41 PM
Mort's Avatar
Well the Maf wasn't dirty. It looked brand new.
Old Jun 11, 2007 | 05:59 PM
Mort's Avatar
Well today I was able to track down a copy of the installation instructions. I went over the instructions and install and found that 2 of the vacuum line were on the wrong nipples on the intake. I switched those and went for a drive, no more problem.
Old Jun 11, 2007 | 06:08 PM
Brettus's Avatar
Boosted Kiwi
ah sooooooo .
would not have thought that would make a difference - unless the lines are from totally different areas of the intake the vacuum should be the same .....
Old Jun 11, 2007 | 06:34 PM
Mort's Avatar
The nipples the lines connect to are all in the same area, but at different heights and different angles. On the Factory intake each nipple is color coded to match the corresponding vacuum line. On the MS intake they are all the some color, polished aluminum, so you need to look at the factory one to see where each line goes on the MS intake.
Old Jun 11, 2007 | 08:45 PM
glad you got it worked out... good job.
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Forevermore
Sep 20, 2015 01:04 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
