No Heat....
Old May 29, 2007 | 08:43 AM
Element's Avatar
No Heat....
Any suggestions on where to look if my RX-8 has absolutely no heat? When the **** is turned to the hot side it just spews cold air. I know there is a TSB but my dealer fails to acknowledge it because it is an "American TSB and not Canadian"
However the TSB does not seem to describe my issue as I have absolutely no heat.
Old May 29, 2007 | 09:48 AM
Rems31's Avatar
Is your car under warranty? They should still fix it if the heater isn't working with or without the TSB. Go to another dealer.
Old May 29, 2007 | 10:48 AM
Element's Avatar
Only powertrain warranty.
Old May 29, 2007 | 10:56 AM
saturn's Avatar
i pwn therefore i am
Check your coolant level in both your radiator and overflow tank. Without it your car may shut down your heater unit to reduce heat under the hood. Might seem a little counter-intuitive, but it's happened to me.
Old May 29, 2007 | 11:56 AM
The only way to fix this is to replace the HVAC.
Replacing the **** will NOT work.
It happened to me once, replaced, everything works.
ivory8
RX-8 Multimedia/Photo Gallery
25
Jul 17, 2009 10:52 AM
kgoh2262
Far East/Asia
9
Jul 22, 2004 08:51 AM
