anyone run more oil pressure yet?
Old May 28, 2007 | 04:40 PM
j9fd3s's Avatar
so ive noticed that the rx8 uses the 71psi oil pressure regulator.
on the fd's mazda bumped the oil pressure to basically the same levels as the racing engines, 110ish psi.
this does a couple of things. most important being more oil being sprayed to cool the rotors.
ive put plenty of fd regulators into non fd cars, and theres no noticeable down side.
the upside seems to be better reliability, and slightly better oil temps
any thoughts?
Old May 28, 2007 | 04:54 PM
staticlag's Avatar
The Professor
I think that the oil system of the RX8 has a blockoff plug or something that stops too much oil from going around the rotors.
If you really wanted more cooling you could just remove that(just like they do for racing purposes), but the downside is running your engine too cool on the streets.
Old May 28, 2007 | 08:43 PM
olddragger's Avatar
remove the plug and put a thermostat in.
OD
Old May 28, 2007 | 08:55 PM
j9fd3s's Avatar
oil coolers have thermostats too, afik
btw, i need a new grammar regulator, thread title's a little, well apples and pears
Old May 28, 2007 | 10:05 PM
j9fd3s's Avatar
thats another thing too. all the previous mazda racing engines, have been run at 115psi, and 9000ish rpm redline.
from personal experience, our ex IT/PS1 engine's bearings are BEAT after being revved to 9400rpm for a season. rest of the motor looks fine. its a stock 89-91 non turbo with fd corner seal springs, and the fd oil pressure regulator.
seems like the rx8's run hot too, and with those giant coolers, they shouldnt?
mr. GrandGame
Sep 9, 2025 10:41 PM
9krpmrx8
Nov 5, 2015 11:45 PM
talonhart2
Aug 26, 2015 04:14 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
