Fan still run even without the key ???????
Old May 26, 2007 | 05:16 PM
totaleclipse's Avatar
Hi all, here is the problem. After running for a good 30 min. or so with the air on. When I turn off my car and take the key out. The fans in the engine stay of. Is this normal???? By the way the temp. is about 85 outside and I shift around 4500 on each gear (normal driving). Any info will be great. thanks ahead
Old May 26, 2007 | 05:19 PM
supergoat's Avatar
I don't "smell good".
It's normal. On hot days the car will sometimes keep the fans on to cool itself down.
Old May 26, 2007 | 05:24 PM
mikeferz42's Avatar
13BEAST
it will stay on for as long as 10 mins. if dumb people ask you what that is, tell them you have a turbo and you're car is still on because of the turbo timer.
Old May 26, 2007 | 06:22 PM
The problem is... It will will by battery and my car would need a jumb to start.... Sorry I know this is a newbie question. My last car was 2.0L turbo with a timer so if the timer ran out everything stop.
Old May 26, 2007 | 07:36 PM
expo1's Avatar
He's as bad as Can
It hasn't killed my battery and I have had my 8 since 2/2004. It normal, let the car do what it was designed to do.
Old May 26, 2007 | 08:06 PM
magikone69's Avatar
the 1st time this happened to me i was actually amazed...i live in s florida where its ***** out hot...and it was an esp hot day (temp meter said 91)...after getting out the car i herd the fans, so i popped the hood and felt a rush of hot air hit my face...figured too it would drain my bat but after reading here i was reassured it would be ok.
Old May 26, 2007 | 08:56 PM
The only reason I bring this subject up is because my car needed to be jumb start twice this week. I had to charge the battery with an external chager after the second time. I might just have a bad batt. I'll let you guys know if it goes out again.
Old May 27, 2007 | 03:25 AM
SmokeyTheBalrog's Avatar
Thread Pirate, Ahhrrrrr
What year Rx-8 do you have?
Old May 27, 2007 | 03:46 AM
FenixTTZ's Avatar
You probably have a bad battery. My temp above the radio has hit 116 but for the most part the fan stays on when I shut the car off.
Old May 27, 2007 | 04:21 PM
TheKDog's Avatar
2007 BB RX8 GT
This was freaking me out. I would turn the car back on then off to shut the fan off. But then I found out it was normal.
Old May 27, 2007 | 10:34 PM
Its normal, nothing to worry about.
but come on, every car does that, why ppl make this sound like a *rare* case?
Old May 28, 2007 | 10:43 PM
thanks everyone for you reply. I'll have the baterry check if it goes out one more time.
Old May 29, 2007 | 02:53 AM
Detrich's Avatar
幹他媽!
wow, no flaming the newbie on this thread... we are getting nicer here
Old May 29, 2007 | 07:35 AM
I'll be the first one then.
SEARCH YOU SON OF A *BEEP* , MAN WHAT PART OF SEARCH THAT YOU *BEEP* DONT GET ?
THE FAN IS ON BECAUSE THE CAR FEELS THAT ITS STILL TOO *BEEP* HOT ! GOD DAMN IT U LITTLE *BEEP* FACE !!!
drebbrnator
Dec 27, 2018 07:02 PM
maichristopher
Sep 7, 2015 09:16 AM
D13
Aug 28, 2015 12:21 PM
Nisaja
Aug 6, 2015 01:27 AM
